Question about Black & Decker Bread Machine
Paddle shaft unable to rotate in the breadpan.
Model no B2200. I have had three of these machines and one new breadpan.All four breadpans have developed the same problem.Why?Is there a quick fix?
  • 433 Answers
Hi, There is a sealed bearing in the base of the bread pan. When this sealed bearing fails the paddle gets stuck and will not turn. Take the pan out of the machine and see if you can turn the paddle by hand. If it doesn't turn freely, then it's probably the sealed bearing that is is failing. If it turns freely, then this is good news. Keep the pan out of the machine and go to a kneading cycle. Look through the lid window to see if the motor shaft is turning. If it is not turning, then a belt fell off , needs to be tightened, or has broken. Motor, belts and pulleys are in the base of the machine. Remember to unplug machine before working inside the machine. Finally, make sure the pan is seated in the machine correctly. Good luck Hankl
Posted on May 12, 2010
Paddle shaft in pail(bucket) seized when I tried to use machine after it sat in cupboard for over a year. Black and Decker (all in one pro) B1650 cannot get shaft to rotate even after soaking in...
Recommend you keep soaking in hopes is will loosen up. Other choice is to search on the secondary or used market for a used bread pan.
The normal sources for replacement parts indicate they are no longer in stock. You could also try contacting the following parts suppliers to see if they can recommend a breadpan from another model that may be compatible.
Try here:
http://www.partsourceplus.com/contact_us.php
or
http://www.abtecparts.com/parts_enquiry.htm
Oct 31, 2011 | Kitchen Appliances - Others
The Breadmaker is not working properly
If the finish is worn and damaged and rust is impeding turning of the spindle you may wish to consider replacing your breadpan.
try contacting the Toastmaster parts supplier to see if they have a breadpan for your model. You can make a web inquiry here:
The comnpany does have parts for many other models so there is some chance they may be able to provide a compatible breadpan. For reference:
http://www.partsourceplus.com/toastmaster-parts-accessories-bread-makers-c-51_1268_1277.html
Oct 23, 2011 | Toastmaster Breadmaker's Hearth 1193 Bread...
I have a toastmaster 2# breadmaker, model 1198. The bearing in the breadpan no longer turns free. Where can I find a new breadpan, or at least a bearing kit?
Hi and welcome to FixYa. I am Kelly.
This is one of the few sources that I know of for Toastmaster breadpans and the only source for Toastmaster parts that I am aware of:
http://www.breadmakerparts.biz/category/1198/catId=3449212
Here are his NEW breadpans:
http://www.breadmakerparts.biz/item/1198/1198-pan-w-handle/lid=5937619
You can contact him here:
http://www.breadmakerparts.biz/contact
Thanks for choosing FixYa,
Kelly
Mar 01, 2011 | Microwave Ovens
The gears underneath are frozen and won't turn the paddle inside the pan. Is there anyway to unfreeze the gears. It appears that the gear grease has all oozed out and the gears underneath are fused and...
The gear grease you are referring to is from the sealed bearing on the bottom of the pan. This has failed and will not allow the paddle to rotate. There is no replacement parts, and a new bread pan is needed. Sorry..Hank.
Jun 10, 2010 | Toastmaster TBR15 Bread Maker
Paddle shaft and seal replacement
Best bearing company I know of is Tri-State Bearing In Evansville IN. They have an unbelievable selection of high quality bearings. But you will have to specify ID, OD, thickness, material preference, sealed vs. unsealed and temperature range. Or you could try RepairClinic.com online and find parts by make, model, etc.
Apr 24, 2017 | Kitchen Appliances - Others
I have a locked up breadpan. Need another
This happened to me also. I looked on Ebay but they were so expensive ($19.95 + $10.00 s/h) so I just went to Walmart and bought a new machine for $52.00. Seems they don't provide new bread pans so you have to buy a new machine. Oh well. Not a true solution, but hope this helps.
Someone posted a comment that they soaked the pan overnight in soapy water and it freed up.
Hank
Aug 11, 2009 | Sunbeam 5891 Bread Maker
Breville breadmaker model BR1 breadpan
seems like we all have the same fault with this breadmaker - and we all cant find the solution easily - looks like breville really dont have much of a customer care section do they - i suppose they think you should just go out and buy a new one -i am still hunting for a new pan and paddle - looks like they're as scarce as rocking horse **** !!
Jan 12, 2009 | Kitchen Appliances - Others
Where can I find a replacement breadpan for the breadman tr2200c?
I found the part at
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
http://www.saltoninc.com/
Nov 13, 2008 | Breadman TR2200C Ultimate Bread Maker
Black & Decker Bread Machine Logo
404 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
