Question about Kenmore Elite Oasis 27052 Top Load Washer
F1 signal machine keeps stopping and then get f1 signal
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
Keep getting F1 code.
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it. I recommend checking this air hose for pinches, twists or crimps. If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced.
Jan 21, 2011 | Kenmore Washing Machines
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an F1 on my washer and it stops. I then have to reset it. How do I fix this?
There is a recall for this machine. The F1 error code is for a "failed control board". Call 1-866-698-2538 to have it repaired.
Happy Holidays The FixYa Team
Dec 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The f1 code on the Maytag Bravos top loading washer keeps going off and stopping the machine
Please contact Maytag to inquire about the code F1. They should check the system and that that code is a courtesy repair and should be scheduled for a someone to come out to fix it. FREE
It is possible that the F1 code was caused by your laundry habits (detergent), but I think that is unlikely. Too many of these machines have problems with the F1 error code. There is a known problem with the Oasis / Cabrio / Bravos machines.
Aug 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
F1 error
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Jul 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I get an F1 signal when I start the washer. I can get it to go away by switching what kind of load it is but it keeps coming back?
F1 means communication error, Unplug washer for 2 mins.. What might have caused this problem is a power glitch of some kind.
Jan 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F1 keeps coming on and stops cycle.
F1 is a primary control failure. First unplug the machine,open the control panel. Locate the p-11 connector. Unplug it and re-plug it securely. If the code continues or the machine fails to operate,replace the machine controller.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis 27052 Top Load Washer Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
