Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Gas coming out of the air filter when generator is off and it wont stay running for long
  • 905 Answers
Your float is likely sticking open, or more likey has a pinhole leak and is now full of fuel. The float isn't able to rise to level of fuel in the bowl and allow the needle to sit into the seat. The seat could also be damaged / have debris on it. First thing to do is remove the carburetor to check for debris and such in the bowl. Then check float, needle, and seat. Since you have the carburetor off anyways, put a rebuild kit in it.
Posted on Jun 12, 2010
My generator is a Kubota DG 7500 and it wont stay on high idle while running
diesel ?
clean fuel filter ..check pump is ok
adjust governor
or twig up idle a bit
Nov 02, 2016 | Electrical Supplies
Wont stay running just dies out when you give it gas
it is a problem with either or both the fuel mixture coming out of the carby or poor quality fuel. use premium 95 octane to help it and you might need to adjust the screws on the carby to generate a better fuel air mix
Feb 15, 2014 | ATVs
Husky generator 1850 watt wont stay running
does ithave fresh gas theres a chance there is water in the gas if thats not the case is the choke could be stuck on or the carb. is gummed up
Oct 28, 2012 | Husky Electrical Supplies
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Got a honda 5hp 4 stroke engine on a generator wont run with air filter on runs perfect without can you help
Check to make sure the filter isn't plugged. If it is good, look below the filter and see if it touches or interferes with the governor spring or the governor rod on the carbueratior linkage. Thos are anout the only situations where an air filter would keep an engiine from running. Marvin.
Jan 12, 2010 | Honda Air Tools & Compressors
Wont stay running
the problems is in the carburetor, common problems when unit does not run often and rust get get build up. get some automotive carburetor cleaners and spray it heavy in the carb, don't worried about flooding it or damaging anything, it will dry out faster than gas. (use little gas if you need to) try to start it up and get it running with the carb cover off and continue to spray carb cleaner in the carb while the engine is running, do this couple of time and hope that would clear it out. if that don't work you will need to take it apart and clean it. you have small tiny object obstructing the carb flow. the unit doesn't have a fuel pump, it run on gravity feed, the carb are easily obstructed. hope that help a bit
Sep 30, 2009 | Coleman Powermate Premium Plus 6250W...
Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Jul 15, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Cant get truck to stay running
did you try the fuel filter
May 20, 2009 | 2000 GMC Sierra
Starts but wont stay running
Check your gas filter. When you ran out of gas, you got any rust in your lines and filters. Change the inline filter and use an air compressor and blow the line TOWARDS THE TANK. Take the gas cap off first. There is also a filter in your tank.By blowing the line you may unstop that filter.
Apr 03, 2009 | 1988 Ford Aerostar
Generator is burning oil and choking out
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
734 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
