Question about Bosch Evolution 300 SHE33M06UC Built-in Dishwasher
No water getting into unit tub? I don't think it now shuts off as it was still running this morning when I got up. Thanks Bob
My LG front loader is showing an "FE" error. The water seems to continue running into the tub, leaking out the door.
Good morning
I looked this up to make sure I was thinking the right way. The FE means there is too much water in the machine... lol bet you already knew that. Since water is actually coming out of the machine it looks like a bad fill valve. The plastic piece your hot and cold water lines hook into is not shutting off all the way.
I hope this helps
Nov 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
We have Kitchenaid Dishwasher KUDP02FRSS1 that does not drain water fully after the normal wash + heat dry cycle. There is about 1 inch of standing water at the bottom of the tub. Pressing Cancel button in...
The situation is most likely linked to the previous cycle not being completed when you press the Cancel button. Most likely the controller is not timing correctly or the water is not heating enough.
Are the dishes hot at the end of the dry cycle?
Sep 13, 2011 | Dishwashers
Tub fills with water when not in use. Can't hear it running, but fills about a gallon overnight. I set it to spin and drain, it empties, next morning it has a gallon again.
your water solenoid valve is bad,unplug the unit and see if it still runs in about a gallon w/o the unit powered from the wall even if the unit is shut off,then you will know its a defective water valve
Oct 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I got in the tub one night after the filter had been cleaned out by the roomate who kept the tub running. That night the temp read 94 but was set to 99. Then the OH light came on with Balboa topside...
at pump housing is an upper/lower bleeder ( about 1/2 inch bolt ) unscrew the bolt letting air out until water runs out than tighten turn on unit and loosen bleeder again bleed out any leftover air tighten
Oct 25, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Doesn't fill with water - goes straight to agitation.
open the console and find the pressure switch. it has a clear hose attached to it. pull the hose off the switch and turn on the washer. if water starts to enter shut it off and blow through it back to the tub. some piece of junk may have plugged it causing the switch to "think" the tub is full of water. put the hos back on and run a short spin cycle to reset it and try again making sure to run a small load to see if it shuts off properly. if no water enters when hose is pulled off most likely bad pressure switch. keep the lid closed while doing these tests. some units wont work w/lid open.
May 25, 2009 | Whirlpool Washing Machines
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Bath tube plumbing is making vibrating sound then shutting off
Replace the cartridge even if its new. The vibrating is from the internal workings of the stem. It also effects the volume of water.
good luck, Phil
Dec 11, 2008 | Plumbing
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Bosch Evolution 300 SHE33M06UC Built-in Dishwasher Logo
20 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
