Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I cannot get internet unless I directly install my ethernet to the modem. IF I intall it to the router and then the modem I do not get internet access.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 68 Answers
Thats because you have a filter in between the modem and router. Or try using a Splitter on the wall jack.
Prasanth 83
Posted on May 11, 2010
New modem installed and router won't work now
First step is to make sure if the modem is working. Connect your computer directly to modem with ethernet cable and see if you can log on to internet! if yes
next step connect modem to your router's WAN port with an ethernet cable and then connect your computer to one of the LAN ports of router with ethernet cable. Power down all devices and power up modem first wait until all lights are on and then router wait until all lights are on then your computer! 9 out of 10 times this works! try good luck!!
Sep 23, 2011 | Dynex 4-Port Ethernet Broadband Router...
Can I connect Ethernet to the internet without router
This is possible a few different ways:
-Connect the switch directly to the modem and each computer, then pay your ISP for extra IP addresses for each computer, if they will allow it. Make sure that you secure each computer with proper firewall/security software as it will be directly exposed to the internet. This method typically will not work with ADSL or any ISP that uses a PPPoE connection.
-Install two ethernet cards in one of the computers. Connect the switch to one ethernet card and the modem to the other, then enable internet connection sharing.
-Acquire an older computer with two ethernet cards in it and install free linux based router software such as Smoothwall to create your own homebrew router that has all of the features of the pricy linksys/netgear/etc. routers and then some.
May 01, 2011 | Edimax ES 3116P (ES-3116P) Networking...
I want to connect my all-in-one with my desktop-computer and router.
1.Your Modem you have with your ISP (Internet Service Provider) has an Ethernet cable coming from it
2.Plug the Ethernet cable into the Internet port of the router.
3.Unless your desktop computer has wifi capabilities (Wireless) your will want to plug an Ethernet cable directly from your Ethernet port of your computer to one of the 4 ports of your router.
4.This will allow you to connect 8 devices wireless around your home with your desktop computer Tethered (Hardwired to your router)
Mar 22, 2011 | Computers & Internet
I did what the direction said and im not on the internet what can i do
Make sure that you have the cables hooked up correctly. The ethernet cable going from your modem should be connected to the port labeled WAN or Internet on the back of the router. Also, make sure to unplug the modem for 30 seconds, and plug it back in. This will clear out any MAC addresses that the modem has stored. If this doesn't work, try resetting the modem and starting over. unless you are trying to set up a wifi password, there should be no setup necessary for wireless routers.
Mar 02, 2011 | NetGear WNR1000 Router
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Automatic installation failure
unless you were switching from DSL to cable Broadband, there usually wouldnt be much reason to rerun the software just because you got a new computer. when you ran the software the first time on the other computer, it was the router you were setting up, not the computer.
if the new computer is not getting internet when hooked to the router, try this.
1.turn off computer and unplug electricity from router and cable modem.
2. connect all ethernet cable to the right location. ethernet from modem to router goes in the non-numbered port, ethernet from your computer to router goes in numbered port.
3. plug in cable modem electricity first, wait for all its lights to come on like normal.(this part is important). the ethernet light on the modem (it might be labeled ethernet, link, pc link, or something similar) will not be lit, this is normal until you get to the next step
4. plug in the router electricity, give the router 2-3 minutes to get connected to the modem.
5. start up the computer, wait for everything to fully load and check internet again.
hope this helps.
Mar 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
Lost intall disk
Well, i have set up several routers and they actually run better without the setup disk. as long as you know how to set it up, you it will work fine. (Setup disks tend to be over controlling of your network.)
To setup:
-Unplug your modem of all plugs.
-plug in your cable wire to the back of the modem.
-Plug in the ethernet wire from the modem to your router.
-Turn on the power(plug in) to your modem and give 2 mins.
Plug in ethernet cord from router to your computer.
-Plug in power to your router and give 30 seconds.
-power on your computer and give 1 min after start up.
-Make sure your internet is working and you are good 2 go.
Mar 23, 2008 | NetGear WGR614 Router
Internet connection
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
194 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
