Question about Dryers
I have a whirlpool stackable set of high efficiency dryer and the alarm sounds off many times before the clothes are dry. I check the screen and clean it but the alarm still goes on numerous times. What can it be?
  • 185 Answers
Can i have the model number please
Posted on Mar 28, 2008
Why is my Whirlpool cabrio platinum dryer leaking water, and taking over an hour to dry clothes?
Is this an older dryer? Long drying times are often caused by lack of good heating or poor air movement through the drum. Air movement depends on a properly turning fan and a clear exit of hot moist air to the outside vent. Check and see if you get a strong blast of air from your outside vent. If you don't, you may have a fan problem, plugged vent, or kinked vent tube. The water leaking could be because you don't have any drying going on due to the aforementioned problems.
Feb 05, 2016 | Whirlpool Cabrio Platinum High Efficiency...
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
I am renting a house that has an old whirlpool stackable washer/dryer combo. The dryer doesn't heat up very much and it takes 3 hours to dry a small load. Landlord had a tech look at it and found...
Under normal operating conditions, the hot air blown into a clothes dryer's tumbler reaches a temperature of about 175 degrees Celsius.
If its getting hot at all, the problem is with the amount of air that it is dispensing, maybe due to the fan not turning or the duct being plugged up.
Either way there is a problem that needs to be examined.
May 11, 2011 | Dryers
My Kemore stackable dryer does not work properly. I have to run the dryer 3 or 4 times to dry a load. Does feel hot at times when I open the dryer and feel the clothes.
Perhaps you have an air restriction of some sort. Cleaning the dryer and checking the vent can greatly increase efficiency. I recently replaced the glides and belt on one of these and made some repair photos. The dryer was plum full of lint all over the controls and everywhere. I took a shop vac to it before I snapped the pictures later that day. I have included a manual also HERE.
Dec 27, 2010 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Alarm sound while drying
It sounds like you have it on the "wrinkle free cycle". (I can't remember what the cycle is actually called with out looking it up.) It will tumble your cloths and then alarms to tell you to take them out before they wrinkle. If you don't take them out, it will tumble them again and alarm again, etc.
Apr 13, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Does not dry clothes. I can run it for three hours before they get dry. The outside of the machine is very hot to the touch. Vent seems to open as I can feel the exhaust outside.
Although you may feel the exhaust, the airflow my not be sufficient to dry your clothes efficiently and costing alot of money on your utility bill. A hot machine is a good indicator that this is the case. Proper airflow across the heater is important to maintain heater efficiency. If airflow is poor, the heater will overheat and eventually fail. If the vent system goes through the roof, the vent screen is probably blocked. If the vent system is longer than 10ft, there is probably lint accumulated in the pipe. Check out this site http://www.linteater.com/.
Remember..the purpose of the dryer vent is to get rid of moisture. If the moisture can't be removed quickly....the clothes will take a long time to dry, no matter how much heat there is....
Jun 19, 2008 | Whirlpool Dryers
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
