Question about HP 373314-001 - HP Multibay II 8X Laptop DVD-ROM Drive DVD Drive
HP laptop DVD drive will not open when I press the buttun. Once open by a paperclip, the dvd drive will not read. Ive tried restarting, nothing. Tried reinstalling driver software. nothing
  • 107 Answers
If the laptop is in warranty , Try contacting HP ! Looks like the drive needs replacement
Posted on May 11, 2010
How do I open the dvd tray
is there not a small button on the laptop.
Feb 12, 2015 | Acer Computers & Internet
How to remove the DVD drive
Turn off and unplug the laptop, some where on the bottom of the laptop will be a single screw, about 5 inches from the DVD drive edge of the laptop, remove it, it may be a long. Once that is removed, open the drive's tray, using a paperclip (stick it into the "very small hole" in the front DVD drive draw, and press it in slowly...) the door/draw will open. Grab the door/draw and slowly pull out, IF it doesn't come out, you may have removed the wrong screw... try again.
Jul 17, 2012 | Toshiba Satellite A65-S1065 Notebook
Hp g62 wont play or eject
The first thing you can try is to put a paperclip into the small hole in the front face of the dvd drive to pop open the tray (if you can't get it open). If you put in a CD, and it won't read it, and put in a DVD and it won't read it, then chances are your DVD drive is no longer working, and needs to be replaced.
Jan 16, 2012 | HEWLETT-PACKARD Hewlett Packard HP G62 -...
Today I inserted a DVD into the reader on my laptop NPQ320H and it did not start to read the DVD, next I tried to eject the DVD but nothing happened. When I open the control panel the DVD does not show up...
on every dvd drive on any laptop there shoud be a pinhole to eject the dvd. use a paperclip insert it on the pinhole and it will eject the dvd inside. if your dvd still not working after ejecting. right click on my computer then click on manage then go to device manager and check if your dvd drive is detected. if its not detected there something wrong with the drive and has to be sent for repair
Jun 21, 2011 | Samsung Computers & Internet
Dvd player on my hp computer will not open to insert dvd or cd's
If it doesn't eject right when you press the eject button right after you power it on, then its not being locked by software and there is either a defect with the button mechanism, the ejecting motor, or the power system.
If you don't need to use it often, you can try manually ejecting it with a paperclip. If it reads the cd / dvd discs, then it is just an issue with the button or motor. If it won't read discs then you'll probably need to replace the unit. If your HP is a desktop, you can use any type of drive (BluRay, CD DVD DL, R, RW etc), as long as you verify it has the same data / power connectors (PATA / SATA). If your not sure the difference, here is an image of two hard drives that have the different connections: http://www.advantage77.com/images/Pictures/Hard_Drives/sata.jpg
If you have a laptop, you can try contacting Hewlett-Packard with your model, product number, and serial number (on bottom of the laptop) and they may be able to send you an appropriate replacement.
Another alternative would be a using a portable USB disc drive.
Please leave feedback if this was helpful. Thanks.
Apr 15, 2011 | HP (381400-001) (381400001) Plug-In Module...
Dvd drive won't open
you can try opening it with paperclip if it's stuck. Straighten the clip and locate a small pinhole on the drive it and insert the clip in. You might need to push the paperclip in an out a few times to eject the drawer.
Jun 19, 2010 | Computers & Internet
CD tray not opeing
Perhaps it didn't fully latch so the CD drive doesn't think it's closed? Try opening and closing the door manually by straightening out a paperclip, then inserting it into the little hole in the front of the CD door. That should open it. Once open, close it and see if it will now open when you press the Open/Close button.
Aug 26, 2009 | Acer (KV.16X04.007) DVD Drive
Dvd-rom drive doesn't open
Sounds like the drive eject motor is broken, maybe time/easier to by a new DVD Burner?
Mar 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
HP DVD WRITER 840b - CD/DVD Tray won't open??!!
Problem of tray opening on hp dvd burner. I got the door open as suggested above with paperclip. Then took some CRC 2-26 plastic safe electrical grade lubricant and swabbed the pivoting door mechanism. Opened with the paperclip about 5-6 more times until it finally opens normally.
Feb 28, 2008 | HP (176135-630) (176135630) Internal 48x...
Cd/dvd tray won't open, no response from button to open
Follow this solution below, or use a paperclip inserted into the tray hole and it will open for a temporary measure, or go to your drive in my computer, right click and select eject and see if it will open. Try also uninstaling your dvd in system properties, by right clicking and select delete, then restart pc to see if it's found again, but when the pc boots it should check the drive, you will notice the light on front of dvd light up, if not there is no power or the dvd is dead.
Jan 09, 2007 | Acer Aspire 3000 Notebook
HP 373314-001 - HP Multibay II 8X Laptop DVD-ROM Drive DVD Drive Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
