Question about Sentry Fireproof Safe
Sentry 1610 Been trying for some time to get support data from Sentry on a 1610 safe. I am having trouble opening the safe after many years of storage. I have replaced the 9 volt batt. But apparently there was also a coin sized battthat is missing and I dont know the type/model for it. Im hoping you may be able to assist with that data. The Sentry website does not list/support the 1610 model safe which I find unusual but the safe is more than 5 years old. Id like to get it open wiht out destroying it. Thanks Curt Browning [email protected]
  • 667 Answers
Hmm, Those coin sized cells are fairly common as to types used. CR-2016, CR-2025, and CR-2032 would be my guess...
Posted on Mar 28, 2008
SOURCE:
How do I remove instructions jammed in front?
Sentry Safe Not Safe - YouTube
? 5:14
https://www.youtube.com/watch?v=CmAQN6hJ1wQ
Jan 21, 2012 - Uploaded by lolitsmexd
Video blogging about Sentry Safe and how easy its to break into one. For a Fire Proof and Water Proof safe ...
Open a sentry 1610 safe - YouTube
? 3:46
https://www.youtube.com/watch?v=vdI6m24GIKs
Mar 9, 2014 - Uploaded by Brad Snoke
There is an actuator inside the front that seems to fail... ... NewSentry Electronic Fire Safe Opened in Seconds .
Nov 14, 2015 | Sentry Fireproof Safe
How to open a Sentry 1610 fireproof safe if combonation has been lost?
I would consider drilling out the lock (have locksmith do this)
Sep 06, 2014 | Sentry Fireproof Safe
I have a sentry safe 1610 that my combination will not open it. Is there anyway to reset the combination or open the safe
Take the safe to a safe specialist in your area. They have a way to open the safe. Because safes are meant to be SAFE - codes are not divulged.
Nov 20, 2009 | Sentry Fireproof Safe
We forgot the combination to our Sentry Fire Safe Model 1610 HELP
Contact SENTRY
Sentry Group
Attn: Dept. 200 882 Linden Avenue
Rochester, NY 14625-2784
Please allow 7-10 business days, upon receipt of your request, to receive your combination.
This request may be faxed to us at : 585-381-2940.
The combination will be faxed or e-mailed back to you only if requested to do so on your correspondence and you have included a copy of a $15* money order on your fax (please allow 24 hours for processing your faxed request).
To pay by MasterCard or Visa please contact our Customer Service Department at 1-800-828-1438 (please do not fax your credit card number).
Jul 31, 2009 | Sentry Fire-Safe Media File - SEN6720
Sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Mar 29, 2009 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Oct 09, 2008 | Sentry Fireproof Safe
Safe codes
Sorry to say it's worthless. next time you see one charge them to haul it off.
Aug 24, 2008 | Sentry Fireproof Safe
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Jul 02, 2008 | Sentry Fireproof Safe
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
I let bettery go too long
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx...
you shuold find all the answers there. Try turning the keypad mount clockwise to open it, and you should have access to the battery terminal. Put new batteries in and you should have no problem with the code.
Jan 17, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
874 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
wickedoneroc
Level 1 Expert
ray012965
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
