Question about Sony Playstation 3 (PS3) Console
My PS3 screen is too large for my regular TV
Hi, I shut off my ps3 a day ago, and when I went to turn it back on, everything was enlarged a little bit. Not too much, but, the screen displaying on my TV was too big, and the normal home screen of the ps3, cannot fully be viewed because of the enlargement. Its the TV I think because when I turn on my regular TV, its normal. When the ps3 is on, its a little bit too big for the screen. Its very bothersome, and I need some things to try. When I try to play games on it, some of the things on the bottom of the screen cannot be showed because of the enlargement. Any suggestions?
Did you ever find a solution for this? Mine has done this and i dont know if the kids hit a setting or what happened.
Posted on Oct 04, 2011
Did you get this fixed, Im having the same problem..
Posted on Nov 17, 2012
Hi, I bought a brand new ps3 console yesterday and everything worked fine when I set it up. I did not have to change any settings in relation to the display at all and it was perfect when I tried out my...
Hi.
No you shouldn't need a new TV, all you need to do is reset the video settings, follow the guide below >>>>>
  1. Make sure that you have only 1 type of video cable connected between your PS3 and your TV or monitor, an HDMI cable is optimal. If you have multiple video connections the reset sometimes does not work.
  2. Make sure that your TV or monitor is turned on and set to the proper input for your PS3.
  3. With your PS3 in standby mode, turn your console on using the front power button and hold the button down.With the button held down, You will here one beep when the console first turns on, and, after about 4-5 seconds, you will here a second beep. When you here the second beep let go of the button.
  4. If you watch the screen you should see it flicker once or twice and then your system should boot up and go to a screen to confirm your video settings. Simply confirm the settings and you should be able to resume playing your PS3 as normal.
  5. If your system does not boot up and give you the confirmation screen for your video settings, then you should shut the system off and restart the system as normal. This will usually finalize the reset of the video settings.
  6. If your system still is not displaying video then please repeat steps 1-5 again. It is unlikely but, you may have to reset the video 3-4 times before it works with your console. The reason for this is unknown.
  7. The procedure to reset video ,on your PS3, should be complete at this point and you should be back up and running as normal.
NOTES: PS3 "slim" models are always in standby mode when plugged in. PS3 "fat" models must have the rear power switch turned on. If you are only using the composite video cables, then there will be no confirmation screens for your video settings.
Regards.
Jan 01, 2013 | Video Game Consoles & Games
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
What to do with my Ps3??
Your PS3 auto-adjusted to the HDMI Input cable, so you will need to find somewhere that you can either get an HDMI cable or a HDMI TV, so you can view the screen. Then you can hook up the A/V jacks and go to your Videa and Audio Output Settings and choose them, disabling the HDMI hookup selected. Then you'll be back in business!
Sep 29, 2009 | Video Game Consoles & Games
The other day my ps3 was working great and today i went to use it and all that i have is a black screen. Know i have it hooked up with a hdmi cable and the tv does recognize it because when i turn on the...
It may have the changed somehow, try turning off your ps3, wait 10 secs, turn the ps3 back on and do not release the power button until you hear the beeps, it should reset your display.
Aug 02, 2009 | Video Game Consoles & Games
Cascading white craziness
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
May 11, 2009 | Sony Playstation 3 (PS3) Console
My ps3 doesnt show any screen on my regular tv anymore !!!
You will need to change the display settings back to normal for a standard TV. Obviously a little tricky if it's already hooked up to the TV that won't display a picture! If you do a manual (or is it called total reset?) this should revert it back to standard TV settings. To perform the reset hold the power button down for 10 seconds (I think it's 10 anyway) or until you here a couple of beeps and it should reset the display settings to it's default.
Hope that helps? Sorry I cant be more exact on the reset details.
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Hi guys
the lightning probably fried the system
Aug 11, 2007 | Samsung HC-P4741W 47" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
1,048 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
