Question about Price Pfister Laundry 2 handle Polished Chrome Faucet
I need an aerator for my cupc price pfister laundry room hose end faucet. will part #941-791 fit?
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
  • 101 Answers
SOURCE: trying to take apart to find the leak
Turn off water supply, if its a single handle there should be only 1 set screw then diverter is screwed down. After you remove the diverter there is a small rubber washer or o-ring ..let me know which it has.Thankyou.
All Price Pfister Parisa Collections products are backed by the Pforever Warranty, which guarantees both finish and function for the life of the product.
Posted on Dec 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: price pfister faucet handle drops and turns off.
There is a price pfister little emblem under neath the handle. Use a but knife and pop that off. Once that is off there is a allen bolt in there. Tighten it up, put the emblem back and away you go
Posted on Feb 14, 2009
  • 92 Answers
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
  • 39 Answers
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
Posted on Aug 04, 2009
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
How do you remove the aerator housing from the Price Pfister hanover double handle bathroom sink faucet
most aerators are screwed into the faucet
IF you use a pair of multigrips with clothe folded in the jaws , you can apply gentle pressure and turn it out
too much pressure and you will distort the aerator so be gentle with it
Jun 01, 2016 | Price Pfister Plumbing
Price pfister faucet repair classic cupc
hand sprayers are often designed to aerate
Oct 17, 2013 | Plumbing
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Sep 23, 2012 | Price Pfister Pfister T26-4ypu Rustic...
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Replaing sprayer
The Price Pfister web site has a video showing you how to disconnect the hose. Basically, you have to push the hose end into the junction block and then grasp the gray plastic fitting, pull the fitting, NOT the hose, away from the junction block. This sounds good in theory, but when upside down with your hands stuck in a small crevase under the sink, it can be a real challenge. Go to the Price Phister web site and watch the video. Good luck.
Rick120977
Oct 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet leaking pull down sprayer spout type
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Price Pfister Laundry 2 handle Polished Chrome Faucet Logo
117 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
