Question about Apple iMac G3 Desktop
I completely shut down my computer and now it wont turn back on is there a certain button i have to push
  • Prasanth Prabhakar
    Prasanth Prabhakar May 11, 2010
    please clarify the whole issue
    President:
  • Apple Master
  • 1,619 Answers
Due to its age you probably have to replace the motherboard battery and boot from the original install disks to set date and time for it to start back up again.
Posted on May 14, 2010
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
Power button lock icon keeps popping up on screen. tried to push reuird buttons to fix. buttons on monitor are not working properly.
Push and hold your monitor's POWER button until the monitor shuts off completely.
After it is shut off, press the POWER button again to turn it back on and the lock should be disabled.
Sep 04, 2011 | ViewSonic Va2431wm LCD Monitor
Hp 6910p laptop wont turn off. Fan running. what gives?
Something is keeping it from shutting down. This could be caused by a faulty application or driver. My suggestion is to hold the power button down until the unit completely shuts down. Take out the battery, unplug the ac-adapter, attempt to power it on and then put the battery back in. Attempt to restart the computer.
Good Luck!
Mar 29, 2011 | HP Compaq Business Notebook 6910p - laptop...
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
Coffee Makee shuts down and won't turn back on
It's little computer may be scrambled, or its channels may be clogged with scale. You might try (1) unplugging the unit for several minutes to reset the computer; (2) descaling the unit with a vinegar solution.
Sep 27, 2009 | Cuisinart DCC-1200 Coffee Maker
Yesterday, I left my computer to talk with a
I would need some more information to completely help you. When you say you walk away and the pc shuts down and starts back up, does it close down (reboot) or does it go into screen saver / sleep mode? What button did you push for the power button light to blink? Have you put the PC into sleep / hibernation mode by pressing the power button once.
Apr 07, 2009 | Gateway MX3225 Notebook
My smartpot shut it self off and wont turn turn back on
try holding the reset button down, plugging it in, and then releasing it after maybe 5-10 sec.
if your familiar with computers.... try repeatedly pushing the reset button as you plug it in... kind of a total reset
other than that it sounds like a glitch.... how long have you had it.... Mmm, consider calling the company and explaining complete mechanical failure. Hey, you never know if you don't try. Happy Holidays... best of luck
Dec 24, 2008 | Rival 38601 Smart Pot 6-Quart
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
WONT TURN ON!!!!
Why don't you just take it to Best Buy2.gif or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Samsung YP-K3 MP3 Player
Apple iMac G3 Desktop Logo
73 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
