Question about Canon Speedlite 580EX II TTL Flash
I mounted the Canon 580EX II to my Canon 5D Mark II. When I using Manual Mode, I can't set the shutter speed more faster then 1/200 sec. Is this problem normal/limitation of it?
    Brigadier General:
  • 3,006 Answers
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
Posted on May 24, 2010
Live View doesnt allow operation of 2 sec delayed shutter. How do I fix please?
You use Live view to get an accurate focus then turn live view off and then once 2 sec delay has been selected (this can be done before going into Live View) release the shutter.
May 01, 2016 | Canon Eos 1ds 1d 5d Mark Mk I Ii Iii Iv
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
I can't get my 5D mark iii to operate at night with available light
Try using manual focus - if the autofocus won't work, because of low light, then you can't take pictures.
Jul 23, 2017 | Canon 1d 1ds 3d 5d Mark Ii Iii 1v 1n
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
My MK2 will not change the iso when in video mode
Have you tried to put the exposure mode to "manual"? If you leave it in automatic exposure mode, the iso, speed and aperture will always combine themselves to give the correct exposure and therefore will not let you overexpose your video. Hope this will help.
Dec 22, 2013 | Canon EOS 5D Mark II Digital Camera
I have been using my Canon 580ex ii with my Canon 5d mark ii. It will not fire at all now. I also tried my old 420 ex speedlite and it will not fire either. But, they both work on my Canon 40d.
You can actually set the external flash not to fire in the menu settings of your camera. Check there or try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Oct 08, 2012 | Canon Speedlite 580EX II TTL Flash
What are lenses that are compatible with the canon eos 5d mark ii
You can use Canon EF lenses. Be careful not to use EF-S lenses, as they cast a smaller image circle for cropped-sensor cameras, not big enough for full-frame cameras.There are other third-party manufacturers that make lenses with Canon EF mounts, such as Sigma and Tamron. Each manufacturer has their own designation for cropped-sensor lenses, so you'll have to check the specifications for each of them.
Apr 22, 2012 | Canon EOS 5D Mark II Digital Camera
Canon 580ex II strobe issue
This depends on the mode you have selected on the flash gun. If you have Multi selected you will get the strobe effect. The strobe effect is all so present to help the flash set the correct exposure. It's not a problem with the flash or the camera. Spend some time reading through the flash gun manual. I have to admit it is not always clear. Also try Youtube for a video.
Sep 21, 2017 | Canon Speedlite 580EX II TTL Flash
Canon 5D and canon 40D are they type A or type B cameras as per 380 EX manual
Hi Bruce,
You have the latest cameras and they will work with ETTL II with Canon 430EX/550EX/580EX and 580EX II. Earlier models use ETTL and films use TTL.
Hope they are helpful.
atdlee@netzero.com
Jan 13, 2010 | Canon EOS 40D Digital Camera
I have the 580 ex2 mounted to a eos 5d mark 2. When up close and zoomed in, the bottom of the photo is dark. The owners manual says to tilt the head down 7 degrees, but its down as far as it will go. Help!
The shadow is caused by the lens and lens shade if you use one. If you are shooting "up close and zoomed in" regularly, get yourself a ring flash. It fits around the end of the lens = no shadow.
Other ideas::
Light it from below/behind or from the side. Put your 580 on wireless, and place it along side the subject. I recommend a reflector on the side opposite the flash.
Use a piece of white paper as your reflector.
Oct 18, 2009 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580EX II TTL Flash Logo
402 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
