Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Need tool to adjust carb on a ppb 100 polan weed eater
If I find a tool how many turns from bottom out to have a proper setting as it cam from the factory.and can I get a carb kit for this model.?
  • 333 Answers
1 1/4 turns out. Then let it warm up and adjust 1/8 turn lean, which is in, to make it run best. But that is only right if you just rebuilt it and everything inside clean and wrkn right. May have to adj in less?
Posted on May 11, 2010
Testimonial: "Very good info thanks, bob"
  • Biggdex35
    Biggdex35 May 11, 2010
    And a screwdriver is all you need to adjust carb. Use the carborator number to get a rebuild kit. It is probably a walbro. If there is like adjusters on carb with stops on them just pull straight out and they will slide offl.
Is there a special tool to adjust the Hi Low fuel mixture on a mc culloch t55 hedge trimmer
Anon, you may need a special type screw drive bit. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Lifetime Warranty 2 Cycle Carburetor Adjustment Tool 4 Piece...
carburetor tool
Adjusting weed eater carb without special tool
Carburetor Adjusting Tool eBay
May 25, 2016 | Garden
What tool can you use to adjust the carburetor on ryobi gas weed eater
depends if u have the export only carb , because if you have the C.A.R.B. model it's not adjustable (other than idle) , if you have the export only version then there are two small plastic caps on side that can be moved aside and screws can be accessed to set HI and low speed jets
C.A.R.B = California air resource Beauru
Apr 18, 2015 | Ryobi Garden
Carb adj craftsman bushwhacker 37.7cc
sounds like you have a weed eater that needs a carb adjustment... you need a special tool
Aug 29, 2014 | Garden
Petrol weed eater will not start. Alomost starts
Hi Mark, I own a shop, we will not work on ryobi, have you gotten 2 seasons out of it? If so thats probably as good as it gets. But you can check carb settings. In the USA they come with limiters on the adjustment screws, not too much you can do(break them off) back your adjustments counter clockwise 1half turn.
Dec 20, 2010 | Ryobi Three Trimmer Combo
Trying to get my Poulan BVM 200 to start consistently. Need a service manual or help with the carb adjustment screws. Does anyone have a manual or a good description on how to do a carb adjustment?
These machines are typically at the bottom of the food chain when it comes to quality control and workmanship. Many are sold, but many turn to junk. You probably have the splined-head screws typical of a lot of these carbs..a Zama possibly. They have the carb adjusting tool for these for sale on Ebay. There are other home-made ways to loosen and adjust these screws too. Consistent starting probably won't be achieved till after you install a carb diaghram or rebuild kit and replace any old fuel lines and filter. Some of these engines run great and some are lemons.
Aug 13, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
Mar 13, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Sep 20, 2009 | Garden
Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Mar 30, 2009 | Garden
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
893 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
