Aopen 945 m8
No video signal
  • jankbh Mar 28, 2008
    using an aopen i945gm-pilf system with 2gb ram kingston kvr533d2n4/2g and pentium (r) dual core processor E2180 ang 250 gb ide hardrive and liteon dvddrive , system fan starts up an d hdd light is on but no video signal and no beeps.
    When I remove ide cable from drives then they power up otherwise nothing please help?.
    barebone systen from Aopen epc945
  • jankbh Apr 16, 2008
    Thanks for your help, I changed my cpu til a pentium D 3 ghz and now it works like a dream, pity that the motherboards only supports older generation cpu's, but at lleast it works
You are using the wrong cpu, you must use intel dual core pentium D and NOT E
Posted on Apr 13, 2008
SOURCE:
Bizhub 951how to remove code c-0104
Dear Noorul,
Your question seems to be related to a copier. It is categorized under tv & video. I hope this is the information you are looking for:
Code
C-0104
Description
Abnormality of the vertical conveyance motor (M8) power in the printer control board (PRCB). An error detection signal (blowout of ICP) of M8 is detected when M8 is turned ON.
Causes
• Vertical conveyance motor (M8) • Printer control board (PRCB)
Konica Minolta bizhub Pro 951 Error Codes
Sounds like you have some replacement of parts that are needed. Let me know if you need a service manual. I will look for that.
Blessings!
Jul 05, 2017 | Televison & Video
No signal detected message on monitor, cpu and monitor are on
Good Day Jboone563!
You need to check if the VGA cable is properly fix to the monitor and video card. Loosen connection or no contacts is the reason for the "no signal" display on your monitor.
This means that there is no signal coming out from the video card, going in to your monitor. If by fixing the VGA connection did not fix it, try removing the video card from the motherboard and then reseat it properly to the motherboard slot.
If this do not resolve the problem, Jboone563, I'm sorry but you will need to replace the video card.
May 26, 2011 | AOpen 19" LCD
How to fix aopen F75PS Display Power Light Blinking, Display Won`t come on.
A blinking power light typically means there is no signal from the video card, so check the connections and try another monitor (or plug the monitor into another computer) first to see if the video card is perhaps the real culprit.
Mar 14, 2010 | Computers & Internet
No VGA signal on AOpen EPC945-m8
From your description, it sounds like once Windows starts it's switching to a video mode your monitor doesn't support. Try starting in safe mode or in vga mode, then check your desktop settings. Set the monitor resolution for 800X600 or 1024X768 at 60Hz refresh and restart. All recent monitors will support those rates, so you'll be able to get back to Windows.
Jan 24, 2009 | AOpen EPC945-m8 (95EP4596B1) Barebone
SOUND PROBLEM
Hi M8!
Try to reinstall the drivers for your soundcard, you can download them from the link bellow
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2669
If you find this helpfull for yu, dont forget to vote!
Good luck to you
Dec 11, 2008 | E-Mu 0404 Sound Card
Video card driver for mx46-533v
Your driver can be found here:
http://www.driverstock.com/AOpen-MX46-533V-driver-download/29-9-12776/index.html
It's the last one on the page.
Save it to disk and keep it handy.
Good luck.
May 11, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
MP915-X Video Output
check out this link and see if it might be something that may be part of the problem and possibly a fix. - http://usa.aopen.com/userdownload_List.aspx?RecNo=10334&Model=MP915-X
Sep 06, 2007 | AOpen miniPC Duo MP945-VX Barebone
Open Questions:
Computers & Internet Logo
569 people viewed this question
Ekse
Marvin
Marvin
