Need via usb 2 driver for vista 32bit some of my ports don't work. motherboard is dfi AD77 cpu athalon xp 2400 vista as been updated from windows update center every week
  • 807 Answers
Look here:
http://www.dfi.com.tw/Support/Download/driver_download_us.jsp?PRODUCT_ID=1010&CATEGORY_TYPE=null&STATUS_FLAG=A
Posted on Mar 28, 2008
Audio driver for EMACHINES 5250 Running on windows XP PROFESSIONAL
Click start control panel administration tools computer management device manager scroll through all of your devices
If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: Motherboard name sound drivers.
Place a tick in either windows software or all software box.
You might have to try a few times to get it right.
Nov 14, 2013 | E-Machines eMachines Desktop PC
Kd7a drivers for windovs7/vista
Hello try the homepage:
http://abit.ws/page/en/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Or the intel download site:
http://downloadcenter.intel.com/
And run the update utility.
Features
Processor
Supports AMD-K7 Athlon/ AthlonXP/ Barton FSB 200/266/333MHz Processors
Chipset
- VIA KT400A / VT8235CE chipset
- Supports Hi-Speed Universal Serial Bus (USB 2.0)
- Supports Advanced Configuration and Power Management Interface (ACPI)
- Accelerated Graphics Port connector supports AGP 8X /4X (0.8V /1.5V)
Memory
- Three 184-pin DIMM sockets
- Supports 2 DIMM Un-buffered DDR 333/400 (Max. 2GB)
- Supports 3 DIMM Un-buffered DDR 200/266 (Max. 3GB)
LAN
- On board 10/100M LAN
Audio
- 6-Channel AC 97 CODEC on board
- Professional digital audio interface supports optical S/P DIF Out.
You can`t use xp drivers for windows 7, it does not work that way.
This mainboard is from the year 2002, and you probably can`t find any drivers for windows 7.
The mainboard is too old, for the windows system.
Continue using windows xp, or buy a new mainboard or pc.
Good luck
Jan 17, 2013 | Abit IP-95 Motherboard
Need a sound driver for Microsoft Windows Vista,
Need to go to vendors site (Mobo) and download drivers for it. Instal mobo one first.
May 10, 2010 | DFI AD77 Pro Motherboard
I have upgraded to windows 7. I cannot use the
“To install, and Update Hardware, click to open "Computer” from the “Desktop”, check to see if there is a DVD-RW Drive (D :), for external different (E or F:).
I. Look in the “Device with Removable Storage area,” see if the device is present, if so? Do the following: to “setup” the ('player') for “Installation.”
II. Right click on (DVD) “Media Player” select (“Install”) follow all instructions thereafter.
III. If the area is (Blank?), “go to,” and 'click' on the "Start button" click all “Programs” scroll for a Media Disk Player”, open, and do the (“same as above”) for the installation. *Note: “Do the same for “Setup” (above) “Install.”
“If this solution helped, ratings it is appreciated, thanks.”
May 02, 2010 | DFI AD77 Infinity Motherboard
Need a sound driver for Microsoft Windows Vista, my computer: manufacturer - DFI model - AD77 Chipset - VIA KT400 (VT8377) southbridge - VIA VT8235 LPCIO - Winbond W83697HF Please help, because I dont find...
ok i had a Qick look for you and found nothing seems its all xp drivers i can see i spend 30 to 40 mins looking for you and only found xp drivers a fast and easy fix is to get a pci sound card you can get a 5.1 channel sound card pci it slots in easy too for 5 to 6 pounds on ebay hope this helps and sorry i couldint find the driver
Mar 17, 2010 | DFI AD77 Pro Motherboard
Upgrade to windows 7 caused a heap of problems
Have you tried other USB mouse?
It might just be a problem with your USB mouse, the other thing is you can also try plugging-in USB devices on your USB ports to test them like (USB flash drives)
You can also try to use PS/2 mouse to check if the problem is really the ports.
With regards to the drivers
It seems like you need to download those.
Because even you downgraded your system to XP, still the OS needs the driver for them.
Ad for the DVD drives problem
YOu can try to open up your CPU
then reseat the cables for the DVD drives.
Mar 01, 2010 | Computers & Internet
Usb ports on processor does not work
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Expand the "USB Serial Bus Controllers" branch.
Any "yellow" or "red" icons indicate that the device-driver software for your USB ports is not installed, or it is incorrectly installed.
Since your Shuttle motherboard uses a VIA chipset, VIA says:
For Win2K and WinXP, due to licensing agreements, a VIA USB2 driver package cannot be distributed online. Driver support for VIA USB 2.0 controllers requires Windows XP SP1 (Service Pack 1), Windows 2000 SP4, or system upgrade through Windows Update.
So, just run Microsoft Windows Update, and look in the "Optional Hardware" section for available downloads for the USB 2.0 ports on your motherboard. Select and download and install the update.
Dec 10, 2009 | Shuttle MV43VN Motherboard
Bios actualization
Click on the DFI link below;
http://www.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=biosTab&windowstate=normal&mode=view&downloadFlag=true&itemId=228
Everything you need is on the site. Just follow the instructions on the site.
Thanks for using FixYa!
Mike
May 25, 2009 | DFI AD77 Pro Motherboard
SATA hdd is not recognized by winXP intallation
First u have to update ur bios and then USE HIREN BOOT CD to repair  HDD
Oct 11, 2007 | DFI KM400MLV KM400...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
