Question about Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher
Bosch shx33a05uc/14 dishes are milky with white chalky residue. Have cleaned the inside, and checked to make sure the water can exit the spray holes in the circulating parts (top and bottom). Checked that hoses are not kinked too. Seems like it's rinsing with dirty water.
  • Bosch Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Mar 03, 2011
White residue on dishes when the dishwasher cycle has completed, not sure why, salt is fine. Is this limescale?
Hi
Make sure that the water is being heated up by your dishwasher. Also need to make sure that the wash motor is spraying water around at full force.
Best way to check this is to start a normal cycle about 10 minutes into the cycle open the dishwasher door during the cycle. 1st observe if the water was being sprayed around as you opened the door. 2nd feel the water and see if it has heated up.
Reset or cancel the cycle and wait for the water to empty. make sure it is draining properly and also check to see if filter is clean.
I'm inclined to think your machine is not heating the water.
Ash
Sep 09, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHX33A05UC model that I bought 8 years ago won't clean my dishes anymore. Replaced spray arm. still won't clean
Hi newbould4,
Please follow my below Tip on how to get the best results from your Dishwasher:
DISHWASHER NOT CLEANING WELL ANYMORE...
Kind Regards d")
JEDEMEYER1
* If this solution helped you, please rate it
Jul 31, 2011 | Dishwashers
Glass and cutlery has a chalky white film after washing
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 21, 2011 | Dishwashers
Chalky milkey white residue on dishes / dishes not clean
heatman101
Nov 08, 2010 | LG LDS4821 24 in. Built-in Dishwasher
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My dishes come out cloudy?
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Oct 18, 2009 | Bosch Dishwashers
Rinse agent won't dispense in Maytag dishwasher
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Apr 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Bosch Dishwasher
Most Bosch washability issues have to do with the machine not pumping out fully.
Check for a partial clog in the air gap:
That's the silver dome on the back of the sink. Not all homes have an air gap for the dishwasher. (Though it is highly recommended!) Lift off the silver cover. Unscrew or unclip the plastic cap on the top. Look inside. Toothpicks are often found there.
Check for debris in the sump by:
Remove the lower rack, the lower spray arm, and screens. Use a #15 Torx bit to remove the cover over the drain pump suction. Remove any debris you find.
Regarding the white residue, make sure the rinse aid is filled.
Mar 10, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch 24 in. SHX33A05 Stainless Steel Built-in Dishwasher Logo
713 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
