Question about Belkin (F5D7230-4) Router (587009)
Out of nowhere the router just lost connection to the internet do you what could of happen, because all the pluggins were correct and i'm really confused right now
My wireless products (ipad, iphone, laptops) pick up my wireless d-link router, but will not let me log on. Why? I lost connectivity out of nowhere. Called cablevision. They verified it wasnt a modem...
Solution:
1. Clean cookies, history, temporary internet, etc, using software CCleaner (free).
2. Turn off the computer, disconnect the d-link router from the computer (disconnect the cable from router to the computer).
3. Turn on the computer, wait until desktop
4. Reconnect the cable router, to the computer.
So, you refresh router and the computer connections.
Nov 27, 2011 | Toshiba Computers & Internet
Lost my internet connection,don'tknow how to get it back
Try going to your wireless router and unplugging it for 30 seconds and pluggin it back in. Wait about a minute and try reconnecting, this happens sometimes.
Mar 06, 2011 | Nintendo DSi White Console
The router keeos on dropping the internet conection after an hour or so.
This problem is common on some routers and the best way to correct this one is to do a firmware upgrade on the router to let it provide a much stable connection , but just make sure the you internet connection is fine when connected directly to your modem so we can really say that the issue is with the router not with the internet service.
Once you;re really sure that the router is the problem you can perform a firmware upgrade on it and follow the step by step procedure from this link, just click HERE.
Jan 05, 2011 | Linksys WRT160N Wireless Router
I lose my internet every now & then. I unplug power supply (6 sec ) plug back in. internet is back on. what's the problem?
unfortunately this is quite a common problem with these routers. There really isnt a whole lot you can do except replace it with one of higher quality. I tried relocating it in the house etc... Tried contacting them and got nowhere either... good luck
Aug 14, 2010 | Linksys Wireless-G Broadband Router
I am on Cox cable. I lost my connection to the internet several times this evening. Cox checked out my modem and said the problem was in the router. When I connect modem to computer, internet pops up...
Cox people are really correct that everything is working from them and from there modem and doing a firmware update is really a good thing to do to correct your problem. For that firmware update you just need to download it from your routers manufacturer like Linksys , Belkin , Dlink or Netgear just go to there web site and search the model of your router so you can download the latest firmware for it.
Feb 03, 2010 | Computers & Internet
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
I currently have no wireless connection. when I
try reseting the router and connecting to it thru an ethernet cable and entering in the default password of admin then reset your wireless internet settings and you should be back online with it
Sep 30, 2009 | Linksys Wireless-G Broadband Router
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Internet connection of psp
To connect to the internet on your PSP, you need a Wireless Router or Wireless Access Point. Once you have a wireless one, you should know the name of your router. That's what an SSID (Service Set Identifier) is.
Once you know this information you should be able to find your router on your PSP. Once you do you should have a password on your router so no one you don't know can use your internet. When adding a connection on your PSP you will also need to enter the password for your router. You can use WEP, WPA-PSK (TKIP) or WPA-PSK (AES). WPA-PSK (TKIP) or WPA-PSK (AES) have very high security and WEP has a lower security.
Once you have added your connection, just type an address and surf! Not all websites will load because some require too much memory.
Assuming you have Official SONY PSP Firmware, Update to the latest version by going to Settings>Network Update. Locate your router and use it as the network connection.
Download the needed files and update by going to Game>Memory Stick>PSP Update.
Once you finish Update, go to Network>Internet Radio>About Internet radio. It will take you to a website to download the files needed and will install to your Memory Stick.
To put music on your Memory Stick, the Music must be MP3, AAC, M4A or WMA format.
Open your memory stick on your computer by pluggin in a USB cable to your PSP and going to Network>USB Connection or you can put the memory stick in a card reader.
Once in the root of your memory stick, there should be a folder called "Music". Put your music in there or in one more folder inside that. Two folders inside of each other will not be playable.
Place videos in the "Video" folder on the root of your memory stick.
Videos need to be MP4 format. 368X208 Highest MPEG4 Codec, or 480X272 x264 or AVC codec.
Need a converter?
http://www.formatoz.com/
Its a free and very good converter. Try it
Reply if you need anything else.
Oct 09, 2008 | Sony PlayStation Portable (PSP) Console
Hooking up Vonage to Time Warner Roadrunner(dsl): Do I have to buy a Linksys Wireless device for my Vonage to work?
You just need a router. and then plug the vonage device onto the router.
Note: make sure you have internet with the router before pluggin the vonage device to it.
Aug 15, 2008 | Linksys Wireless-G Broadband Router
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
