Question about IBM Infoprint 1532 Laser Printer
Lexmark 1532 How do I unlock the controls on a Lexmark infoprint 1532
  • Don  Farrell
    Don Farrell May 11, 2010
    Please let us know exactly what you are trying to do.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    controls? as in the menu on the printer?
  • 13 Answers
If the Operator Panel is locked. (Menu's disabled) you need to enter Config Mode to enable the operator panel. Press and Hold the > right arrow and down arrow buttons while powering on the printer. Once in configuration mode scroll to Panel Menu where you can enable it. Exit Config Mode or just power the printer off and back on.
Posted on Jun 05, 2009
SOURCE:
Why is my infoprint 1532 saying load mp feeder?
Driver is telling the printer to print single sheet. Load a single sheet or fix your driver/software settings.
Jul 09, 2014 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
WHERE IS THE FUSER WAND?
open the long bar at where the paper comes out (under the paper at the top of the printer in the back of the sheet). It has a thumb slide to push it sidewise and then pull up. Most new printers do not have a wand with a felt pad on it - just a scraper. This is attached to that unit when removed (or if it has fallen off - inside the printer.) The wand cleans the fuser (it's HOT) of leftover toner and keeps the print copies clean. it just pops off and pop a new one on (with a pad - hopefully. This is for lexmark 1532 and older printers
Nov 02, 2009 | IBM Infoprint 1532 Laser Printer
IBM 1532 makes a loud bang loading an envelope
That sound is actually the printer sucking the air out of the envelope to flatten it out. It is normal and there is no way to turn it off.
Aug 07, 2009 | IBM Infoprint 1532 Laser Printer
Refilled toner and now printer reads - 30 invalid refill
The toner used must be for a different printer. That error message is displayed when the chip on the toner is not the correct one for that printer. It may be a defective cartridge, or the incorrect model. Try to go back to the place you bought it and return or exchange for the correct one.
Jun 16, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
Tray 1 Low
How many input trays does this printer have?
Trays can be renumbered to allow for larger capacity input trays.
Please print out the menu setting pages and verify the correct paper tray numbers.
Don
May 15, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 printer not working
count the beeps, the number of beeps detemines the error.
Nov 14, 2008 | IBM Infoprint 1532 Laser Printer
Infoprint 1532 ibm micr printer
This unit is the low voltage type 110v compared to Australia voltage which is 230v therefore you will have to buy a new printer
Dec 29, 2007 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Laser Printer Logo
341 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
