Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Cannot get to convergence in the setup and there are 3 dimensional pictures on the TV
It seems that every solution on fixya has a price, even the free ones
Posted on May 15, 2010
  • RCA Master
  • 8,617 Answers
There is a repair kit called the ITC222 and ITC222A convergence option missing repair kit which should repair that issue. Its available from www.tvrepairworld.com and the kit also contains instructions.
Posted on May 11, 2010
My picture is in 3 dimensional pictures. blue, red and green. what is causing this problem and how can i fix it?
the convergence has gone away, in the tv menu, picture settings, or set-up settings, search for an auto convergence
Mar 07, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our tv just had the three colors cross and picture became distorted, almost three dimensional. What could be the issue and is this an easy fix? The auto-convergence option is not showing up either on the...
Blowed Fuse on deflection board FL231. Deflection board is the bottom left hand side, and on the right handside of FBT flyback Transfomer is 3 Fuses in a Roll they will Look like Small brown rectrangler Caps But are Fuses it will be the Middle Fuse that is Bad.
Mats 1-800-628-1118
UED 1-800-648-6657
Jan 07, 2011 | RCA HD52W59 HDTV Projection Television
I have a PT-47WX53 that has one vertical bar down the middle of the screen. Barely visible in a purple hue and about 3-4 inches wide. I'm looking for some suggestions. Thanks
A few simple things you may try. Under your menu on the tv look for convergence or it also may be under setup. Run the convergence setup and follow the on screen instructions. If the tv fails to converge while in setup you may need to replace some things however the parts are very very cheap. If your convergence setup works and you still have a bad picture, and or both, meaning the tv's convergence wont align then you may need 1 or 2 IC's and maybe need to change your coolant in the tv's RGB lens...all can be done with little experience and for under 50 bucks. I can give more detail if needed.
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
RCA 52" Convergence Problem
Replace the convergence power supply. You can get the ITC222A convergence power supply board at the following link under RCA circuit boards.
http://www.tvrepairworld.com/
Jul 24, 2009 | RCA HD52W59 HDTV Projection Television
Sony wide sceen projection tv kp-51ws510, my picture looks like 3 dimensional pictures , with a red highlighted all around the picture,how can fix this?
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | Zenith R57W46 57" Rear Projection...
RCA Rear projection had a 3-d like picture. one red one blue and
Go to menu then setup if you do not see convergence on menu then FL231 is open replace it then do auto convergence.
Jan 02, 2009 | RCA D52W23 52" HDTV CRT TV
RCA HD52W59 Projection Big Screen TV
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply problems....in which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
Convergence problem
Replace convergence IC's STK 392-110 to upgrade STK394-160E Part # CZ 01341 then activate Magic Focus........T.
Nov 25, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Convergence and picture problems
This TV probably uses two convergence IC Packs that will need to be replaced and be re-converged. There may also be a resistor or two that may need replacing as well. The projection tubes should last another 3 years or so.
Dec 26, 2006 | Apex Digital GB43HD09 43" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
127 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
