Question about Woods Upright Freezer MU07W
Thanks, I bought a woods freezer modelco7na-k1 3.0amps, ok my question is it got into a flood and now makes ket ket noise when pluged to the eclectricty but does not get cool
    President:
  • 949 Answers
The issue is most likely the relay that starts the compressor.
Behind the freezer on the bottom is a black device about the size of a bowling ball, this is the compressor. Mounted on the side of the compressor in a box with wires going in is the relay. Unplug the power cord to the freezer. Pry open the box and note what wires go where. Remove the wires and pull off the components from the compressor, they may be tight but will pull off. You should be able to find this at a local appliance parts dealer.
Posted on May 11, 2010
I have a woods fridge
I am going to guess that it might be the fan and it is binding or has come loose and it hitting something.
Jul 13, 2014 | Woods Upright Freezer MU07W
Banging noise
Usually the condenser fan blade hitting on some part of the condenser or shroud.If you can access it, check the fan mountings, and blade for straightness.
Mar 23, 2014 | Woods 201 cu. ft. Upright Freezer V2003RW3
The fan is very noisy
His idea makes sense. If the noise stops sometimes, then pretty much that is it, especially if the noise is near the top of the freezer and not down below. Unfortunately some fans are hard to get to. Best of luck.
Dec 08, 2013 | Woods Upright Freezer MU07W
Freezer is making a loud noise, assume when compressor is on. Pretty much as soon as the door is opened, the noise begins. Things are still frozen inside.
inside the compressor body there are springs which sometimes break and allow the
motor to knock against the outer enclosure. There is no fix for this as the system is
sealed, short of replacing the compressor. Not a problem with operation, but quite
distracting.
On another note, if the freezer compartment is beginning to freeze up or the fan
blade was installed too far back on the shaft, this could also cause noise.
(it will only make the sound in the freezer compartment when the fan is running
if this is the case). Hope this helps.
Apr 28, 2011 | Woods Freezers
Side of freezer seems warm
Hi!!
Don't worry about the line, it is supposed to be the way it is. If you are talking about the condenser coil, located on the back bottom part of the unit, with a small fan in front of it, yes, it is supposed to be hot.
The condenser job is to disipate the heat absorbed by the evaporator (the coil inside the freezer). Make sure the condenser is clean and condenser fan is working, also, make sure there is air circulating thru the back of the unit to help cooling the condenser.
The noises you hear, are probably the defrost coil melting the ice on the evaporator, this function is on a timer and happens 3 or 4 times a day.
Good Luck!!
Aug 03, 2010 | Woods 247 cu. ft. Upright Freezer FU25
Power Light On Woods Chest Freezer
blown globe or neon would not bother dont need it
Jul 18, 2010 | Freezers
We bought a Woods all fridge and upright freezer pair
Do you know what parts are needed? Some are available and some are not.
Apr 24, 2010 | Woods Upright Freezer MU07W
I have a upright frostfree Woods freezer. It is only around 4-5 years old and this year it is making very loud running noises. It is not keeping things fully frozen.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 15, 2010 | Woods Upright Freezer MU07W
Moved locations, pluged it in and nothing
Make sure ther's power in the outlet by plugging in something youknow it works ,if there's not pewer check the breakers.
Aug 17, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Woods Freezer Makes Loud Vibrating Noise at 10pm each night
sounds like either your compressor is loose and just rattling or the compressor is off balance and its rolling around inside the seal can.  take a look at it when it is making the noise.   put your hand on the compressor (careful   might be hot)   if it feel like it running smoothly then i would call an electrician cause that kinda puts me out of ideas without being there...  sorry
Good luck
Jason
Jan 15, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
Woods Upright Freezer MU07W Logo
102 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
