Question about Magic Chef CAV2005A Top Load Washer
Broken Washer? I washed a heavy rug in the washer...the washer stopped working and started smoking. Do I need to replace the whole washer or is it possible that I just burnt up the belt?
    Sergeant:
  • 243 Answers
If it is a belt drive it could have burnt up, If if its direct drive the coupler. these would be the cheap fixes. But in both cases the motor could have burned up. The motor probably cost 120 plus or minus plus labor, a hundred or so. If its old maybe replace. If it was mine I would fix it.
Hope this helps
Robert
Posted on Oct 04, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 68 Answers
No just call a tech and ask him to replace the motor and get it recoilled ,it should fix the issue up
Thank You
Prasanth83
Posted on May 11, 2010
Kenmore he2t
fluff may have blocked the filter or jammed the drain pump. you need to check these
May 07, 2014 | Washing Machines
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Error code f 50 stop and keep beeping
washed to small bathroom rugs.. on bulky items. low suds stopped at F code and can not get to rinse and drain and whole dial lit up. Tried removing one rug of 2 to lighten the load. still not working. Tried unplugging it and waiting. have had about 2 years. HELP.. read the directions.. it appears using bulky items was not wise. over did the agitation.. made too much suds?
Jul 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washed a load of floor rugs now washer will not drain
sorry but one rug is ample for any machine,but the load weight alone is far to much on the machine,i have been in a testing factory and seen the things people put in machines and it would shock you,but back to your presant problem?basicly the whole dranage system is full of heavy dirt and needs cleaned badly.Try putting two dishwasher tablets through machine and see what happens but i must say i wouldnt have high hopes,i would think lower dranage pipes are going to be cleaned.if you want my help come back to me.adrian,,,,,,,
Aug 21, 2010 | GE Profile WPRE6100G Top Load Washer
Stopped spinning from heavy rug
what is error, most likely plugged the pump
Apr 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
My washing machine wont empty or spin it was working the other day and i put a small rug in it that went heavy when it was wet and it stopped working it is a centrex 7 kilo
You drain pump may be full of the rug stuff you will need to open the washer and the remove drain hose to remove what is stuck in the pump.... I have used a shop wet/dry vaccum put on the drain hose to remove stuff... but it will not always work...
good luck
Sep 12, 2008 | Washing Machines
Magic Chef CAV2005A Top Load Washer Logo
Top Magic Chef Washing Machines Experts
Ian Jones
shaun taylor
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
