I have a THERMADOR - Pro Grand - PRD36 that the left side doesnt.
I have a THERMADOR - Pro Grand - PRD364EDG that the left burners don't light. The blue light comes on but no ignition sound or gas comes out. The right side works fine. The pattern on the stove is 4 burners(left/right) and a center griddle. How do I fix this?
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on [email protected] so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do
not use a toothpick or matchstick to clean the gas ports. If the tip of
the wood gets stuck in the burner ports, it could cause a serious
blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
what is the model number? there are too many models to be generic in an answer for you. Most Thermador gas OVENS use glo-bar type ignition.Are you speaking of the top burner igniters? you have too many parameters open here for anyone to give a proper answer to you.
Check your earthing, all the way back to the earth stake too for safetys' sake! Otherwise, try lighting the burner with a gas match instead of the peizeo ignition module >> check ignition module
I have a THERMADOR 6 burners gas unit, if the door is not completely stright, sometimes cause this kind prblems.try to move up and down several times first.
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
