Question about Canon PIXMA MP600 all-In-One InkJet Printer
Ink tank won't light up
I have a Pixma MP600 printer which I have had for about 4 years. I recently tried to install an ink tank (a C-CLI8) but the light does not go on and a message says "The following ink tank connot be recognized". I went to Target bought another Canon tank. Same story. I have read the trouble-shooting guide and have tried everything. Why won't the tank light up? What could be wrong? I'm an 80 year old grandma and love to PRINT! HELP!
SOURCE: MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Posted on Sep 04, 2008
onyeredson
  • 404 Answers
SOURCE: Canon pixma MP600 wont recognize ink tank. Seldom used
Hello!
I have the same printer and the only ink cartridges I use are Canons own.
I've tried these cheaper replacement ones and zip nothing will not recognise them.
It is false economy as now I have a full bank of copy ink cartridges that charity will not even accept.
Hope this helps!
Paul 'W'
Onyer~EDson(:0) {#>< U.K.
Posted on Jan 14, 2009
ksdi
  • 34 Answers
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
11111111
Posted on Mar 15, 2009
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Posted on Nov 30, 2009
pineworks
  • 4041 Answers
SOURCE: I have purchased a
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
The large black ink tank is empty but the small black ink tank is full, why won't the printer print from the small ink tank?
The small black ink is only used for printing photos and must be used in addition to the large one. If the large one is empty, it will not work.
Jun 28, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
U043
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp500 printer
plz check you have placed the ink tank in the appropriate slot otherwise you have to try with new one
Aug 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Charging Ink Tank
same as azin i changed the black tank and the chip but it now prints everything except black
Apr 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Ink carriage will not stop at centre to allow change of ink cartridges
hi star
Try this
After the printer decides the cartridge is empty it will start giving you warnings. Eventually it will give you a message to press the Stop/Reset switch for approx. 5 seconds to disable ink level monitoring on the empty cartridge. Ink level monitoring will be re enabled if a new OEM Canon cartridge is installed. There is no way to reset the chip on the cartridge but you can replace for new ink
oke
cropp
Mar 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
130 people viewed this question
old marine
old marine
