Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE profile fridge : cannot reset non-LCD display
My non-lcd display keeps flashing and I can't reset it. All the lights are on (eg the digital number screen reads 8888). Model number PSCS5VGX. It is less than 2 years old.
Did you ever figure out a fix for this? Mine is now doing the same thing.
Posted on May 05, 2011
Have a GE Profile PFCS1RKZA - with many random issues...
The dimming light indicates a power loss in the system.
Jul 10, 2015 | GE Refrigerators
Frigidaire Gallery GLTF4920ES3 Front Load Washer keeps powering off and on during a cycle. The LED panel goes crazy when it's off, no error codes, just a horizontal then vertical line and random cycle...
To get a diagnostic code out of this take the screws off the lid. There should be a manual on this model. You have to hold start and cancel together with the machine off, but plugged in for 5 seconds on this model. If you had a long fill problem on this unit the machine clunks out and doesn't operate correctly. Refer to that tech sheet to see how to reset the error codes on the unit and try again. If your machine has 8888 display instead of just little led lights, the error codes are much easier to read and understand through the tech sheet. To put the unit into diagnostic mode, you have to set the dial all the way to the specified cycle setting and follow the instructions from there. It will throw only an error code if you hold Start and Cancel together.
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    My t.v was working now all of a sudden it comes on and all i can hear is the sound but no picture
    need a new bulb shut down the tv and wait a few minutes if the light flashes red or green for a few seconds this is a code that you haveto read eg if 3 flashes then start again it means there is a problem read in between the flash code go to google put in the model number of the tv and the flash eg. hlt6187sax blinking codes
    Jan 27, 2011 | Samsung HLT6187SAX 61" DLP HDTV
    My 7 year old GE Profile Side by Side will not get
    Self Diagnostics
    To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
    can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
    illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
    4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
    freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
    For temperature control panels with single-digit displays, the COLDER temperature adjustment button
    will increment the numbers up and the WARMER temperature adjustment button will increment the
    numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
    freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
    the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
    Press the HOLD button for 3 seconds to begin the test.
    For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
    increment the numbers down and the WARMER temperature adjustment button will increment the
    numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
    freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
    code. Press any button other than a temperature adjust button to begin the test.
    When testing has been completed, do one of the following things:
    • Enter code 1 5 to completely reset the system.
    • Enter code 1 6 to exit diagnostic mode. GSS manual
    May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
    You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
    Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
    Camer keeps shutting off...it's burry and powers
    Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
    Do not overcharge.
    Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
    Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    530 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
