Question about HP PSC 2210 All-In-One InkJet Printer
Carriage will not move. Found thin black belt frayed and broken.
Are there spare parts and is this fixable by someone with little familiarity with the mechanics of this printer?
I am not in the mrkt yet to update my 6y PC running XP.
  • 152 Answers
Belt is "Taiming Belt" contact your hardware consultant
Posted on Mar 29, 2008
T1100 unable to detect media edge. replaced line sensor, carriage PCA. Cannot calibrate line sensor. Panel reads calibrate sensor to black but does not print pattern and says "return error: 2".
I have seen this error occur when the carriage does not move smoothly left to right...are the shafts properly lubricated and the carriage belt in good shape (not frayed or teeth missing)?
Also there are special paper considerations for the calibration to work...Bright White Inkjet Paper is recommended., not just plain paper.
Sep 05, 2013 | HP Designjet T1100ps Printer
Frayed & Broken belt found after printing stopped
You should be able to replace the belt yourself by takeing the printer apart, if your not feeling confident about it then you should take it to a pro. a service manual may be availabe.
Jul 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Codigo de error 86:01 Carmotor. C, 2403
Either something is jammed and preventing the print head carriage from moving from side to side, or the drive belt has snapped. Open the window and check the black belt that runs the width of the printer. Check both ends carefully because often the failure happens when the belt frays and gets wrapped around the motor or idler pulley.
Aug 31, 2011 | HP DesignJet 500 InkJet Printer
My problem is after claibration i receive a message POWER OFF AND CHECK PRINTHEAD CLEANER PATH
Something is blocking the printhead cleaner assembly from moving forward and backward.
Turn the plotter off, open the printhead cleaner access cover (RH side) and see if you can move the cleaners to the front of the machine.
If you can move them fairly easily, then try (with the plotter still off) to move the carriage assembly (holds the printheads) to the left of the machine.
Check the condition of the carriage belt for frayed areas or missing belt teeth.
(I suspect a worn out carriage belt is causing the problem)
With the cleaner assembly to the front, and the carriage to the left, turn the plotter back on and see if the error continues.
May 03, 2011 | HP DesignJet 5500PS InkJet Printer
During startup the drive belt slips and gives an error
Open the printer's door and look for the print carriage. It's the platform that moves back and forth over the paper, probably where you put new cartridges. Unplug the printer, and check this belt and its pulleys to see if it's either broken or possibly covered in ink. The drive belt will be black and have gear teeth on it. If you see a metal or plastic ribbon, that's more likely the encoder that let's the printer's computer read the position of the carriage. See if you can nudge the carriage and make it move a little; it may simply be jammed. Check the carriage's moving path and make sure it's not obstructed. Any other problems would probably best be handled by Epson.
Feb 27, 2010 | Epson Stylus R380 InkJet Photo Printer
My printer carriage won't move???? It is an HP C 4180 printer. I put in a new black ink and it jammed. I know how to install the ink and nothing happened that was different except now it won't move. Can...
Make sure the cartridge is firmly seated in its holder. It's possible that the carriage belt has broken or has slipped off the motot pulley. Look inside the printer and locate the flat toothed belt that pulls the carriage back and forth. follow it to either end and make sure that it isn't broken or slipped off the motor.
Jan 24, 2010 | Office Equipment & Supplies
There is a loose ribbed black/brown thin band inside the printer where the cartridges are changed-where does it belong please
Sounds like the carriage belt, it goes around a motor pulley on the far right side, and around a spring loaded idler pulley on the far left. It should also be connected to the carriage assembly to move the carriage back and forth.
Dec 16, 2009 | Canon PIXMA MP530 All-In-One InkJet...
HP Deskjet 722C printer belt has frayed and come apart
Dear DIOGENES2001 ,
Yes , please contact nearly Authorised Service centre for genuine spare .
Cheerup
Mar 04, 2008 | HP DeskJet 722c InkJet Printer
Problem is with a Quasar VHS 960
This is probably part of the cassette carriage (the unit that loads & ejects the tape). You could possibly post a couple of pics- of the loose pieces, and the carriage mechanism- perhaps a tech here could point to where the pieces fit. Hopefully, nothing on the carriage (or elsewhere) is broken. VCRs of the last 10+ years are made to break easily- thin metal, thin weak plastic.
Jun 13, 2007 | Quasar VHQ400 VHS VCR
HP PSC 2210 All-In-One InkJet Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
