Question about Ovens
Oven gets warm but not Hot! Only 50 to 60 Volts AC across the both elements in the Oven.
  • 4 more comments
  • rdthee May 11, 2010
    220 V at top burners, so no blown fuse, etc.
    Sorry, no I meant the 4 Burners on top show 220V.
    Only 50-60 V appear at both the Broiler Element, and the Bake Element in the Oven.
    Resistance on digital Meter on 2,000 ohm scale shows 19-20 ohm, on Both Oven Elements.
    Sorry, Thought Fixya had sent you that!
    This is my First time.
    Range says Tappan, Mdl #31-2649-00-07, Serial # VF41505094.
    Online I can not get that Mdl # to come up with Tappan, But it does come back as Valid Mdl # for Frigidaire.
    I am sorry, the stove is my sons, and he had taken the back off and looked around, did not see anything obvious, he's mechanic and a mechanist so hes pretty sharp. But he is not available right now.
    So How does this Fixya think work?
    Can I Phause or postpone this for an hour or so?
    Nothing looks Burned or Hot.
    60 V appears at contacts of Conrol Swicth also!
    So Must be Control Switch correct?
    Cost to replace Thermostat, or Control Switch is Too Much to be Practical, unless we can find a used one.
    Are These Good Conclusions?
    Yes, Thanks for the Help and Confirmation of our, my son and myself, conclusions. Very good info and quick response. Thanks again, I will be back.
  • 3,037 Answers
If that's the case of only 50-60 volts, you should check any fuses in a service disconnect box, or if it is an older oven there could possibly be a glass fused main panel. Whatever you have to deal with for fuses, check to see what's blown and replace.
Let me know how this works out for you.
Benjamin
Posted on May 11, 2010
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri May 11, 2010
    Do you mean at the boil element you have 220 volts?
  • Benjamin Patri
    I was meaning a fuse in the oven, not in the house. A make and model number of the oven would be good too.
    thanks
  • Benjamin Patri
    Alright, elements are both fine, 20 ohms is a good reading. Generally if it was the temperature sensor (small rod on top inside back of oven), then only the broil element would work. Your problem is in the oven, one of it's components has burnt out that supplies voltage to the elements. Open up the back of the oven and see what you find to start. Generally something just burns out.
  • Benjamin Patri
    Yes, just don't reply until you are ready to and then I get an email notification and will respond when I can
  • Benjamin Patri
    Yes, control switch would be first thing to try and replace. If you worry about buying the wrong part, repairclinic.com will allow you to return any part minus the shipping within 30 days. Sorry about the bad news but if you need anything else, let me know. The model number should work on repairclinic. It did for me.
    Good luck
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
Lower burner doesn't heat up
do you get 230v across the 2 terminals when on? could be a bad solder connection on the underside of the relay board.
Jan 30, 2014 | Thermador SM272 Electric Double Oven
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not heat
GE Oven: If it only gets warm, it is not getting 220 volts. It may only be getting 110 volts. First check your breaker (double pole) and reset it manually. Since it is an older oven, there may be a break in one of the wires or connections. A voltmeter will indicate just how much current you have. Be careful.
Mar 29, 2017 | Ovens
Oven elements warm but do not get hot.
whats the resistance on the elements, how many watts are they?
make sure all wires are good, could have one broke about half way. you will need to check the resistance on the elements. you need to actually check the volts and use whats its closer to 240/220 you will have to find out the ohms so you know the element will get hot. if all the wiring is good start with the elements, you need w/v will tell you the amps. e/i will give you ohms, just use the equations in the pic to figure out what you need to know. it as to have enough resistance to get hot
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
Heating element won't heat. Checked breaker, turned off then on, and can't see any fuses in control hatch everything else is working. reset clock, canceled all timers. What now!
It gets tricky from there...
I would check for power at the element....if there is power and the element is not getting hot then you have a bad element.... 220 volts across the two wires to the element or more is considered proper power...
If there is no power there.... then you need to flow the wires back till you get power and that is where your problem is....
This is the best way to troubleshoot your oven...but a good quality electrical meter is needed.... and you need to be very careful when working with electric as it can kill you!!!
heatman101
Nov 06, 2010 | Dacor ECS127 Epicure Electric Single Oven
Element or thermostat - Neff U1721 cooker
Hi there.
It is possible that the element in your oven is faulty again without there being any external evidence that it is so..
To be certain whether it is faulty or not , you really need to test it with a meter,preferably an anologue one with a audible beep to test for continuity.
What you need to do is disconnect the element, and with the meter probes touch the terminals of the element, if it is o/k then the meter will beep, no beep ,element open circuit.
If your meter does not have a beeper, then set it the ohms range, and again test across the element terminals, if it is o/k then the pointer will deflect all the way across, no deflection, element
faulty.
It is doubtful that it will be a faulty thermostat,if the temp indicator light shows, that shows the supply is getting to the element.
If no light , then yes, it could be stat, to test if it is working, switch oven on, and with the element reconnected, test for voltage with the meter set on 240 volt range,no reading, stat faulty or no power between stat and element.
This should help you sort out what has happened.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Neff U1721 Double circotherm Electric Oven
Replacement Element does not work
If it is a double circuit element, then you will only get 110 vlolts across one circuit, and 220 volts across the other circuit..
If however it is a single circuit element, and you are only getting 110 volts, then I would suggest that you have a high resistance somewhere that is stoping it from getting 220 volts.
Hook the element directly to a 220volt supply and check voltage .
Thanks.
Dec 16, 2008 | GE JRP24 Electric Double Oven
My single glasstop oven
Will try to help here.. First off.. when you measure 120VAC at each terminal for the heating elements..what are you using as a reference? Ground? Since your stove is probably wired 220VAC, I would expect to see something across the two terminals to the element that isn't line voltage.. meaning, when you turn the controller to a setting, you should see something more than 120VAC across the terminals and the current will be controlled to maintain a heat setting. The burner that has an open element is indendent so that should not factor in. Heating elements are nothing more than a big resistor that generate heat when current flows thru them. Just because you have one leg of power doesn't mean you have current flow thru it and therefore that is where I think your problem is... You may have an open leg ..Check the power coming into the oven and make sure you have 220VAC across the two line voltage terminals.. Be careful ( very careful ) when doing this...
Hope this helps.
Sep 18, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
