Question about Whirlpool LGR5636L Gas Dryer
No heat glow plug doesnt lite - Whirlpool LGR5636L Gas Dryer
  • Whirlpool Master
  • 43,501 Answers
If you have a gas dryerno heat glow plug doesnt lite - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshootno heat glow plug doesnt lite - 2_bing.gifc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 11, 2010
10amp fuse for glow plug lite keeps on blowing
Maybe the glow plug relay is at fault?
Mar 11, 2014 | 2004 Opel Corsa 1.3
Rodeo isuzu c190 1981 model ,,no heat on theglow plugs very dificult to start
HI Theo, It is not always a good idea to connect the glow plugs directly to the battery. Did you read the operating voltage of those you fitted. Twelve volt systems, very often use anything from nine volt to eleven volt, but very rarely twelve volt. I suggest that you test each of the glow plugs and replace those which have burned out. I'm fairly sure that when you noticed the problem it became evident with hard starting. That was probably when the first failed. It is very possible that you also have a problem with the glow plug timing circuit in addition to the plugs. Make sure your vehicle is getting a voltage supply when the ignition is first turned on and that it is being fed to the bus bar or connecting cables which join the glow plugs in parallel. If the voltage is correct, I believe that will confirm blown plugs. Regards John
Nov 16, 2012 | Cars & Trucks
Well all the burners turn on, but the oven doesnt turn on, i can see the glow when i turn the nob but it doesnt lite up, like if their is no gas their, i have a Frigidaire model: fgf326wgsf. tomorrow is...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Frigidaire FGF326AS Gas Kitchen Range
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
Hi i have a m reg vauxhall cav 1.9 turbo diesel im haveing trouble starting in the morning and i have changed the following, battery and the glow plugs. engine is turning over for about 8 mins on and off...
if you have changed the glow plugs and it still plays up try changing the leads that run to each glow plug if that doesnt help theres a pre heat box relay which is for the glow plugs should be somwhere near inner wing check it is clicking over after you turn the ignition to start position youll get the pre heat light on the dash once that goes listen ans you should here the box click .hope i could help
Dec 23, 2009 | 1996 Volkswagen Jetta
Will not lite. Glow plug comes on but gas does
check current draw on glow plug if less than 4 amps replace you need more than 4 amps to open bi metal strip for gas to flow over time the material boils off reducing resistance even if it is red hot... you want cake,,,REPLACE IT
Aug 14, 2009 | Dryers
I have 1999 e300 turbodiesel. I am getting check engine lite & coil lite on; could you please help me as what could be the reason? thanks bob
hello,good day,coil lite is your glow plug indicator,maybe your temperature switch for glow plug system is faulty or have corrosion on terminal connection,ty
Jun 27, 2009 | 1999 Mercedes-Benz E-Class
Glow plug system does not seem to work
Likely, I would check the glow plug relay.
Mar 24, 2009 | 1996 Ford F350 Crew Cab
Doesnt wnat to start (1989 7.3 diesel)
hey buddy,,, does ur 350 have a WAIT TO START LITE,,,turn key on a start lite should lite wait till this lite goes out before cranking,,,engine should crank over about 5-6 turns and it should fire up,,,if it don't start , turn key off then on, lite should come on,wait until u hear the solenoid start 2 click, turn key off ,turn on again, lite will lite ,wait till u hear the solenoids click, turn 2 start,if it doesn't start rite up turn key off, grab a test lite 12 v,[ check ur glow plugs,] test lite, place clamp end on positive post of battery ,pull wire off of the individual glow plug, put the point of the test lite on the glow plug that the wire was attached to, if u have no lite the glow plug is no good,if the lite is dim the plug is on the way out ,if the lite is bright the plug is good, move 2 all 8 glow plugs,if there is 1 bad 1 the rest will not function proper,if u r going 2 replace any of them make SURE that they r the rite 1's cause there is 2 types[ don't let the parts guy tell u different[the wire end should not have 2 b altered 2 get it 2 plug on 2 the glow plug,take a sample if u need 2 replace,check the wire end that they r the same,,, tighten snug don't over do it, go through the steps above 2 start, should fire rite up , if it doesn't and u don't hear the solenoids click the controller is the next step, u should have 12 v at the + on ur controller,,, if not ur wiring 2 the controller is out[ fuse; wiring, ignition switch maybe at fault,if 12 v at the controller try the test lite at the glow plug terminal if this functions ur in good shape here,,,2 check and c if u have a lack of fuel[READ AND DO REAL CAREFULL]remove top of air cleaner,,a very short spurt of ether,,, 2 START,,turn the key rite over 2 start[don't activate the glow plugs as the ether may burn the tips off the glow plugs] should start immediately and stay running,,if it stalls,, try same again,,if it stalls again there is a fuel problem,,,check all lines and fittens,,check the mechanical lift pump,,, filters tight ,, bleed system,, remember those starters on these animals cost a p pot full of money so easy on the cranking time [easy on the tantrums keep asking questions and soneone will get u there,,, hope this gives u the help u need Len
Jun 26, 2008 | 1989 Ford F 350
Whirlpool LGR5636L Gas Dryer Logo
1,603 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
