Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
5 year old machine.After wash cycle water appears on floor.Comes from drain trap door on front.Have removed and cleaned filter but problem remains.
  • LG Master
  • 8,220 Answers
Problem:
The seal design on the washer traps water causing mildew to grow.
Solution:
If the door gasket has a small hole at the six o'clock position--it is clogged with soap scum. Use compressed air to blow this hole clear.
This allows water to drain back into the tub
If there's no hole--this is an older model LG which did not have this upgrade
Wiping the door gasket with a rag after the LAST cycle of the day helps prevent debris from accumulating. Some consumers add (1) teaspoon of bleach to a spray bottle with water--and spray the older type gaskets after the final laundry load finished--to keep the gasket clean.
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Lets see what else have I got?
LG WASHER SERVICE MANUAL
GET LG PARTS HERE
Note: Their are limits parts outlets here in the US. I do not work for these parts folks, I thought ya might like to have the link.
What else?
You might get the old CE error one day so I will toss in this which ain't got nothin to do with your problem:
Problem:
Getting a CE error code
Solution:
This is a *rare* error.
It's highly unlikely the motor is at fault.
Detergent overuse triggers an "LE" error rather than "CE".
UNPLUG THE WASHER...
First--inspect all wiring connections at the MAIN BOARD (see below instructions). If good...
Inspect the wiring at the motor--remove the rear service access panel.
Remove the 17mm bolt at the center of the rotor--this can be tight as threadlocker is used (I use an 18 volt Dewalt Impact drill).
Pull off the round shaped rotor. Use some care--this rotor has magnets lining the inside of it--it's not super fragile but can crack if hit sharply.
Inspect the two plug connections to the motor for loose or frayed wiring. Also inspect the wiring which runs from the base (bottom) of the washer-to-the-motor. Once or twice--I have found wiring frayed from the gyrating tub assembly (repair as needed).
If no obstruction such as a nail or similar object can be seen in the drum (small holes in tub)...if the drum turns freely by hand--the most likely fault will be the MAIN BOARD has failed.
This job is very simple:
Remove (3) screws at the top of the control panel.
Pull the control panel towards you & upward.
Posted on May 11, 2010
  • Dan Webster
    Dan Webster May 11, 2010
    If the water is leaking at the door seal the manufacturer recommends shimming the latch receiver with washers to make the latch close tighter. That's a hoot aint it?
My washer will start & then stop. F-20 appears on screen
Most likely there is a bunch of stuff in the drain filter. Remove panel below door. The drain pump is in the front on the right and has a trap you can remove (be ready with a bucket to catch some water). If you have never cleaned the trap/filter and the washer is more than a couple of years old, I'll bet this will solve your problem.
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here- http://service.candy-domestic.co.uk/manuals/pdfs/CNW156.pdf
Jan 07, 2014 | Candy CNW136 Front Load Washer/Dryer
Water on floor around washing machine
If the machine is a few years old the rubber seal between the drum and the door may have perished.
Temporarily, you may be able to remove it and turn it upside down to cure the leak.
Dec 10, 2013 | Kenmore 40272 3.5 cu. ft. Front Load...
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
Washer does not spin. Tried to start cycle over
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 26, 2010 | LG Washing Machines
Washing machine is not completing spin cycle at high speeds. Only goes slow speed tumble for a few times and then stops.
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Jun 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Model # GHW9100LW on final rinse and spin water remains in washer, door locked and humming sound comes from machine....pause/cancel will not unlock door or start new cycle... what might be the problem?
Sounds like the pump is trying to drain the water but something is clogged in it or the pump itself is bad. Door wont unlock if machine thinks there is water inside. Remove front lower panel. pump is in center. Unscrew cap and remove attached filter. Be prepared for water to come gushing out once filter is removed. Clean filter and reinstall. If problem persists then the pump itself needs to be replaced.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mildew in ge front load washer
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
Jun 04, 2009 | GE WBVH6240F Front Load Washer
The control lock does not work. Tryed everything to unlock the
It is not inlocking because of water still in the system, run the drain spin cycle manually if that does not work you will have to clean out the lint trap and the water left inside will drain on your floor. To clean the lint trap. there is a panel at the bottom front of the washer. along the bottom of the washer there are three torx type screws to remove the panel these will be above the drawer unit if you purcased the stand. remove the panel by lifting from the bottom. then in the center you will see a plastic cap. twist the cap to remove. this is your lint filter. it pulls out and has a cup shaped piece attached to it pay attention to how it comes out im not sure if you can put it in wrong. clean the area out. there may be some water to spill out depending on how much is clogged in your system. replace the cap once you have cleaned it out this should help with your problems.
Mar 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
