Have x52 flight control system plus pro flight rudder pedals aprox 4-5 years old,used them on windows EP system. I installed them on new computer seven system.Very poor control when flying,very erratic. Any suggestions would be appreciated.HELP.
    President:
  • 1,070 Answers
Dear Friend,
It seems to be System Configuration Problem..
  • Increase your RAM memory/Size For Instance From 1 to 2 GB/ 2 to 3 or 4 GB (This is Better to high Performance)
  • Install Correct Drivers
  • Use Good Video Card(To know about Some models of Video Card Click)
Use Disk De-fragment
  1. Open up the Start menu, and go to “All Programs”, “Accessories”, “System Tools”, and “Disk Defragmenter”.
  2. Click on “Defragment disk” (for Windows 7), “Defragment now” (for Windows Vista), or “Defragment” (for Windows XP).
In windows Vista/7(Disable Windows Search on your System)
  • Open up the Windows Control Panel, and select “Programs”. In the next screen, click on “Turn Windows features on or off”.
  • Click “Continue”. In the next window, uncheck “Indexing Service”, and hit “OK”
  • Click “OK”, and wait for the Indexing Service to be uninstalled and disabled.
Use only Simple theme>Use only Fewer needed Fonts> Uninstall any Unnecessary Programs and Files(Increase Disk Space)>Try to Use 'Msconfig'(Go to Run and Type) and Choose Simple Booting.. Go to Run type '%temp%' and Enter >Select and Delete all
  • Follow this Guide Click (Unzip it)
  • and Here too..For Drivers and More Click
Hope this make you a conclusion...Thanks for Contacting FixYa...
Posted on May 11, 2010
  • robrainey82 May 16, 2010
    Your response to my problem worked quite well, thank you, however the Pro Fight Rudder Pedals are in my computer but do not respond to the controlls, very erratic. Unable to make settings.
  • shafi
    shafi May 17, 2010
    You r welcome....
    Have you Checked this for better Performance-
    Follow this x52pro Guide Click (Unzip it),
    Flight Rudder Pedals Here too..For Drivers and More Click.
    If you don't install the drivers and just plug it in, it will work, but you lose functionality.You would need to use the latest versions for better working. So check it..
    Go to this Link and read to Fix.To get Common Fix Here..
    >Still have a Problem you may Contact for further Product-
    Support Phone Number: 1-310-972-9930
    Support Email: support@saitekusa.com...
    Hope you get Solved this Problem.....Keep Using.....
Loaded XPlane 10 on new iMac and rudder pedals no longer function?
My iMac has a CD/DVD drive, but I posted a X-Plane 10 pendrive to avoid inserting DVD #1 every session. It functions perfectly. Another point is to connect all peripherals (stick and pedals etc.) BEFORE launching X-Plane 10. Then calibrate your peripherals within XP 10.
I have no pedals set, but instead a pitch-stick with grip throttle and a Logitech joystick with twist grip to fly helicopters.
Jul 29, 2014 | Saitek Pz35 Pc Pro Flight Rudder Pedals
X52 pro mouse function
How to bring up other e-mail that not opened a while: khanhctrinh@gmail.com ?
Jan 13, 2014 | Saitek X52 Pro Flight Control System Game...
I have a X52 pro. Throttle works fine, but the lights on the stick are constanly flashing and the stick doesn't work
if your X52 is less than 2 years old and you have the receipt, it's under warranty. Call Saitek and they will take it back and fix it (no charge). Mine is more than 2 years old so I am out of luck.
Jun 14, 2011 | Saitek X52 Flight Control System
I've downloaded the sst software and drivers for my X52 Flight Controller (NOT PRO) when I downloaded the profiles for the X52 Flight controller ALL of the profiles (pr0 format) say 'can't load file. I've...
According to the manual you can choose your profile by using the clutch function. Are the profiles that you downloaded of the same file type as the one you have been able to make from scratch?
Mar 19, 2011 | Saitek X52 Flight Control System
I'm in Belgium fan of fsx with window 7 64bits with saitek x52 pilot 6.0.4.1(HID-USB) All the bitton are working except one : the twit (rudder). It makes a mouvement (kind of vibrations) around the the...
You should set this axis up first as a rudder in FSX settings, then calibrate it. Make sure you hav the latest drivers for it too. Make sure that Auto-rudder check box is unticked. I hope this helps, good luck
May 08, 2010 | Saitek X52 Flight Control System
The x-axis on my x52 flight control system doesn't work
try runing the install new hardware wizard then try and redownload all your drivers.
Jul 31, 2009 | Saitek X52 Flight Control System
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
k24674
jasbo
jasbo
