Question about Haier Energy Star ESA3183 Air Conditioner
Cleaning We bought a used Haier window unit from someone, and it is very dirty all over. i took the front off and coils, and every other part is covered in dust. What seems to be the fan inside is also dirty but we r unsure of hoe to clean it, anysolution?
    Novelist:
    Champion:
  • 246 Answers
If practical - the best way to clean a unit like you're describing would be by using 'air pressure,' to blow the dust out of the coils, squirrel cage, and in and around the fan motor and compressor.
Then take a water hose and wash both coils being real careful to "not" get water in the fan motor. Note: the compressor is sealed so you don't have to worry about it, but try to be careful and keep water out of the controls/wires (you might even use plastic to protect them).
Also, be sure you install a 'clean/new' air filter in the unit itself. This filter goes in front of the evaporator coil which is the coil that gets cold. The other coil - the condenser coil (the one that gets hot) does not need a filter.
good luck!
Posted on May 11, 2010
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
I have a haier hwr12xc5 window ac unit and its not blowing like it use to what should I do
Possible that the filter is dirty and needs to be clean or the unit ref is possible low
I’m happy to help further over the phone at https://www.6ya.com/expert/vincent_f7b7c5f4dedd2565
Jun 02, 2015 | Haier Heating & Cooling
My ac blows but air does not come out could someone help me
Remove from the window and remove it from the sleeve it sits in,
chemically clean the units coils with a acidic foaming type of coil cleaner available at appliance parts houses and hvac houses too!
Sep 04, 2011 | Haier hwr10xc6 Air Conditioner
The inside front when you open the panel has snow ice formed inside. Is this normal and I have never noticed it before or what is wrong. After we let it unfreeze then it will work fine then freeses again.
Hello, the evaporator coil will frost over for one of 2 reasons, either lack of airflow or low refrigerant charge. start by checking the air filter and clean if dirty, also I would recommnd spraying a coil cleaner on the evaporator coil and clean it. If the unit appears clean then most likely the unit has a leak and will need to be recharged with refrigerant.
Jun 06, 2011 | Haier ESA3125 Wall/Window Air Conditioner
The unit is freezing up and leaking alot of water
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it
May 04, 2011 | Haier HWR06XC9 Air Conditioner
I have to window units that are not blowing out cold air. the fan works. is there a way to put freon in them or do you have any suggestions?
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it. In order to add freon you must add a piercing valve to the low side of the system since most window units dont have service fittings
Apr 28, 2011 | Haier Heating & Cooling
Do I need to clean coils in haier hwro6xc7 air conditioner
You always need to keep both coils clean on your AC.
The evaporator coil (where room air is drawn in and through a filter) - is easy to keep clean - 'just keep the filter changed on a regular basis and you will probably never need to actually clean the evaporator coil. Occasionaly you might need to brush the coil with a brush or something - but this is not a big concern.
The condenser coil (where hot air blows from) is even 'easier,' for you don't have to mess with a filter, just keep the coil clean. You can occasionally pull the unit (when needed) and wash this coil with a water hose. In reality this coil will not get very dirty very fast - although it will (over time) acquire some dirt/dust, but as I say - it is pretty easy to keep clean. Note: Condensing units (split systems) that sit in a yard will get much dirtier much faster than window/thru the wall units such as yours, but you still have to keep a eye on the coil.
A good rule of thumb - is to change the filter (in front of the evaporator coil) - monthly.
As for the condenser coil (where hot air blows from) you can easy see it and just need to keep it clean, with no set (usually) time to do so.
good luck!
May 02, 2010 | Haier HWR06XC5 Wall/Window Air Conditioner
My Haier 5,200-BTU Window Air Conditioner keeps freezing up. how do I remedied this?
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Sep 02, 2008 | Haier hwr10xc6 Air Conditioner
Window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Aug 24, 2008 | GE APN10AA Portable Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
79 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
