Question about RCA P52926 52" Rear Projection Television
Will not turn on--but if we leave it unplugged for a least 2 weeks then it turns on but as soon as we turn channel it goes off again
  • 32 Answers
This problem seems like a defective or leaking zenerdiode in the receiver section. the receiver uses a 32volt zenerdiode that holds the voltage steady at the desired peak. when this is defective its voltage trought this part goes all the way up. especially when changing channels. according the self protection, the tv unit will shutdown when passing the 32 volt.<br /> what you can do is lokate and change this zenerdiode or change the receiver board. i think the last one will be easy if your not handy enough. succes and enjoy :)
Posted on Aug 23, 2010
    Scholar:
  • 142 Answers
Try this: Turn off power and unplug the set and disconnect any peripherals from the set. Hold in the power button for at least 60seconds, then reconnect the power and try it. It may reset, no guarantee though.
Posted on May 11, 2010
The tv is stuck on channel 70. neither the remote nor the tv button will change the channel
1. Unplug the TV from electrical power. Leave it unplugged for about ten minutes.
Dec 12, 2014 | Luxor Televison & Video
Won't turn on led flashes green 8 time
Sounds stupid but I've had this issue with 2 different brand TV's and I unplug them for 5-10 minutes and then they are fine. I just had this happen just a week ago with a TV again.
Jul 14, 2014 | Sylvania 6842PE TV
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
I have a samsung hcj552w rear projection tv. Every time the power goes out the tv will not turn back on unless I unplug it for a week or 2. When the power goes out then it comes back on just the red...
Replace the STK ICs,STK392-020 they are big black ICs and will have Part Number on them.Also CK the Low Ohm resistors in front of ICs. Mats Electronics has ICs 1-800-628-1118
Oct 29, 2010 | Samsung HCJ552W 55" Rear Projection...
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
There is sound but no picture and there is no response when using the control buttons on side of tv or the remote. I turn the tv on and change channels thru Comcast cable.
Talked to a Westinghouse tech and told to unplug for about 3-5 minutes, then re-plug. It's like having to re-boot your computer when it goes down or starts acting wacky. It worked, I got picture. Says it could happen again, maybe 1-2 times a year is o.k., if it starts to happen every few weeks, then it's something more.
Oct 14, 2009 | Westinghouse LTV-37w2 HDTV
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Black TV Screen above Channel 46
Try resoldering the tuner can's connections to the main board.
If that doesn't solve it, you need a new tuner.
Or do what all too many people do, use the VCR's tuner and just leave the TV as a monitor.
Jan 03, 2008 | Televison & Video
Sony kv-32s42 needs help.Tuner problems?
Hi Grasshoppa, I would venture a guess that your tuner is not at fault but most probably the logic circuits controlling it since as you posted, you can tune > get a good picture but "channel numbers in the upper right hand corner ...." If your intention is to use the VCR and thereafter change channel using the VCR, you may use the Audio/Video input. With an RCA 3 cable connector, connect the (Yellow) Video out, (Red/White) L/R Audio out of the VCR to the Video in &L/R Audio in of the TV. You don't need to set the TV to Ch 3 but rather select Video 1 or 2 or A/V. Hope this be of some help/idea to you. Post back how things are or should you need further information. Good luck and kind regards
Jul 27, 2007 | Sony KV-32S42 32" TV
RCA P52926 52" Rear Projection Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
