Question about Jl Audio 500/1 Car Audio Amplifier
My input sensitive switch broke inside where can i get one
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
TRY EBAY for a blown amp as parts or try your local JL or any kind of Audio dealer. hope this was helpful
Posted on May 11, 2010
Stereo channels of Xenyx 1202 are very very quiet
It sounds as if the input is too low. what happens if you plug whatever is going into the stereo channels into a pair of mono channels. Or are you taking about the phono stereo tape input?
The stereo channels are line level whereas the other channels have both line and mic level inputs, what are you trying to put through the stereo channels? You must make sure the gain switch is set to the -10dB to get the most sensitivity (the mono channels have about -132dB max sensitivity BTW) You probably need a different mixer or possibly a submixer if you are needing more than 4 low level inputs.
May 06, 2014 | Behringer Music
On my 03 accord no power to a/c clutch
The a/c clutch circuit is controlled by the PCM on your Accord. It receives all necessary inputs from the car, and the driver's requests, using odvious buttons, switches, pressure switches, and several engine inputs to determine whether or not to engage the comp. Engine load/accel, temp., ambient temp, etc will all affect this. Also, if all seems normal, I have run into two of this generation Accords that had the control circuit drivers inside the PCM burned out by sloppy a/mrkt alarm system installers. These guys wreak havoc on most newer cars, because they aren't trained to properly isolate/disconnect sensitive electronics that can be damaged easily by shorting wires, or tapping into a circuit that should not be used for this purpose, etc. Good luck! And the security/immobilizer systems in the newer vehicles have NO NEED for additional security add-ons. If someone tries to sell you on them, they are scamming you for money, PERIOD.
Mar 30, 2014 | 2003 Honda Accord
I have installed a motion sensitive light outside that is controlled by an Intermatic light switch inside. Is the motion sensitive light incompatible with the Intermatic switch?
as long as the switch operates properly there should be no problem, I would delete the switch from this type of application ,some times more control means more problems,
Jun 12, 2011 | Intermatic Hardware & Accessories
My dryer stop working, when I pused the button for it to come on nothing happens Is my belt broke, or too much lent in the vent.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
May 04, 2010 | Whirlpool GEW9250 Electric Dryer
Lcd model L1928NV takes 2 to 3 dozen times turning on and off to get image stays on momentarily or stays on at times get message "no signal input" any ideas
doug_karr, Well, Why don't you get inside the monitor and find the "thermally sensitive/intermittant, cold, frosty looking" solder joint on the "switch-mode-power-supply"/"CCFL inverter supply" and do a nice touch-up job of resoldering it. Also look for FAILED, SWOLLEN, looking electrolytic filter capacitors and replace them with new ones if required. Read my fixya profile for all your options. Good luck guy.
12fixlouie aka louie12fix
Jan 10, 2010 | Westinghouse L1928NV Monitor
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Aug 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Antenna analog input tunner broke off inside the box wondering if i could bypass it useing converter and the digetal input tunner
Yes, just make sure your converter box has composite and you're set to go. Your antenna will then plug directly into your converter box. If you end up needing more than one port (dvd player, gaming console, etc.), grab up an A/V switch which also works off of composite and you're all set to go.
May 12, 2009 | RCA D52W136D 52 in. TV/DVD Combo
Broke ******** in amp input
If the center conductor of the RCA plug broke of inside the RCA jack of the amplifier, you may be able to push it out from the back. If that's not possible, you may have to remove the jack from the board, disassemble it and then push the center conductor out. If you send me a photo of the jack, I may be able to offer more suggestions.
babin_perry@yahoo.com
Aug 09, 2008 | Sony Car Audio & Video
Sensetivity switch and bridging
sensitivity switch select best position of the input level to get full power when you set level control at maximum. in your situation 26db position is better.
Mar 12, 2008 | Crown CE1000 2-Channel Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
27 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Jamie Henning
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
