Question about Craftsman Garden
I have a garage door opener that when closing it will reverse and go up multiple times. the key pad will only work when i hold the enter button down the whole time. when it reverses lights flash on and off. the main control in the garage has a green light that blinks constantly. it is a craftsmen model 53975 fron 2002. i cannot find my manual and do not know what to do to fix this problem. please help!!
  • georgep104 May 13, 2010
    The solution Silverdragon gave me did not solve the problem, but, the manual he provided gave me an idea on what to check. Overall very helpful. Thank you!!
  • 12,061 Answers
Ok, I have seen similar problems many many times before, now this is happening due to the fact that the transmitter, is "Stuttering" IE: It is sending out, erroneous codes, now this can happen, due to the key pad being dirty, or faulty, the IC itself going faulty, (Common) or on odd occasions the receiver goes faulty there is a fix below, to see if that's it... otherwise use the ,manuals below, also below is a Forum, others have had similar problems with these units, it appears they fault frequently.
Here is a manual below...
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0303178.pdf Now if that particular manual isn't the exact one, this website below, has many, many more models, go there and see if your is there.
http://www.manualsonline.com/ex/thread/view/idThread/1629102
Forum below.
http://www.thathomesite.com/forums/load/garages/msg081857563994.html?5
Most often it is a bad wall control. You can remove the control from the wall and then remove the two wires from the back. Remember which wire goes where. You should try this for awhile to see if it has eliminated your problem. If it hasn't then remove those same two wires from the opener. They go to terminals 1 and 2 and once again remember which went where. One of them should have a small red line called a tracer. Occasionally the normal movement of the opener will cause a staple to cut through the wire insulation and cause a problem like this. You won't get shocked as the voltage is much to low.
Posted on May 11, 2010
    I fixed it. It was the safety eyes. They were not aligned properly. My kids probably crashed one of their toys into it and knockedit off balance. Thank you for your help!
Good Morning My name is Raj. I have a CRAFTSMAN Garage Door Opener 1/2 HP, model# 139.53635SRA (OR) T as the last letter. Issues: I cannot CLOSE Garage Door either with remotes or with key pad by...
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Ok so I am having a problem with craftsman garage door, The sensor light are right on green and one orange, but i still have to hold down the button in the garage to shut the door. Also today i thought...
If when you try to close the door the main light flashes 10 times and the door starts down and then reverses to the open position you have a door sensor problem. Make sure the lights in the sensors are not flickering ever so slightly. The color of the lights doesn't mean anything. The keypad sounds like a separate problem. Make sure the battery is good.
Apr 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
My wired key pad in the garage opens and closes the door but the buttom keeps blinking fast. My two car remotes stopped working. My remote key pad on the house works. Whats with the fast blinking and...
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not continue to open garage door.
You say your door won't open and then you say your door won't close. Anyway you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you tweak them and the lights don't come on then you have either a wiring problem or a bad logic board.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Jun 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door close with wireless remote entry but will not open
It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Clossing Door
If the door closes by holding the wall button you have a photo eye issue. Check your photo eyes for proper operation.
Sep 05, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Garden Logo
26 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
