Question about LeadSinger LS-3000 Consumer Microphone
My video isn't working right
When I connect the mic to older TV's the screen goes black and white and starts to flip and when I hook it up to newer TV's it's still black & white and the screen is off center. It goes to the bottom and I can't see the bottom of the third line.
  • mwrippinit Sep 26, 2008
    I have the same problem, where the screen is black and white and the bottom lyric line is less than half visible. I've tried holding numbers 8 and 0 while powering up to reset the chip, but it doesn't help. I've had the mic for 4 years now, so maybe it just had a circuit go bad. Anyone else have this problem?
I just fixed my problem and the mike is working great! Try holding the number 9 then press and release the power button. I found this on the Leadsinger FAQ section and it worked. I'm pretty happy, as I really enjoy the chips I have for the mic!
Posted on Sep 26, 2008
6ya staff
SOURCE:
Why is my Tv flash black and white and the quality goes bad while using my ps3 while its hooked up to my Capture device?
That is usually caused from the capture device putting out a cross channel that you set is picking up. If the device has a modulator and plays through a CHANNEL as opposed to a connection, check the channel to be sure that it is the right one.
Jun 09, 2014 | Diamond Multimedia Diamond USB 2.0 GC500...
XBOX NOW PLAYS IN BLACK AND WHITE WITH OLDER TV DID WORK FINE AND DOES ON NEW HDTV ALL CABLES GOOD NOT SURE WHAT TO DO TO GET COLOR BACK
There is a switch that changes the video cable from SD( for use with older TV's without high definition connectivity) to HD (used for newer HD TV's with high definition.
If your older television is using a composite (yellow) connection for video, make sure the switch is in the SD position and NOT hd.
Mar 02, 2011 | Microsoft Xbox 360 Console
I have an rt2870 and am just wondering where i connect the yellow subwoofer cord to the TV at, and i set my tv setting for the surround sound
You shouldn't connect the subwoofer to the TV. Just connect the Right and Left audio cables (red and white RCA plugs) to the TV audio out and then the other side goes receiver's audio in. If you are using the subwoofer that came with the unit, connect it to the sub port (purple and grey or black striped). The red and black striped cable goes to the subwoofer control.
If you are using another active subwoofer, connect it to the RCA jack labeled Subwoofer Audio OUT.
If you have a 3-plug RCA cable that is a composite video cable. The yellow plug carries the video, the red and white carry the audio signal. This cable is most often used for connecting older VCRs and game systems to a TV (or newer devices to an older TV). Thus leave the yellow jack dangling if using it for an audio cable.
Set your TV to use the external audio speakers and the receiver will take care of the signal to the subwoofer. (You only would connect the speakers individually for a computer sound system.)
I hope this helps.
Sep 19, 2010 | RCA RT2870 Theater System
Color image is coming out black and white
does it happen on the any input or just on tv setting?
if it's judt tv then sounds like the tuner, if it's on any input, then the video chip or a decoder on that board.
Apr 08, 2010 | Philips 26PFL5322 26 in. LCD TV/HD Combo
Watch camcorder on tv
Most camcorders come with an adapter cable that connects from the camcorder and then has three RCA connections 'Video - yellow', Audio Left 'Red' Audio Right 'White' that you can take and connect to many of the newer style and even older TV sets 'Aux inputs' located on the back, side or even front of the TV screens.
Hope this helps
Blessings,
A/V Media Guy
Nov 21, 2009 | Video Cameras
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Have a Konka TV but ps2 doesnt play through it.
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
LeadSinger LS-3000 Consumer Microphone Logo
195 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
