Toshiba Satellite P105-S6084 Power On Issues
I plug my power cord in, the light comes on, but as soon as I press the power button, it shuts off. It will only do this if the battery is out. I tried it like this then place the battery in. The battery light lit up like it was charging but then it turned green (fully charged) in 10 seconds.
  • Darnuth Mar 29, 2008
    My warranty has expired and I did call tech support, but one: i had a problem understanding what this person was saying, two; they wanted me to pay 35 dollars. I have an extended warranty through Best Buy, but I'm 2 hours from trhe nearest Best Buy. So I guest my only option is to make the pilgramage to Memphis.
  • 44 Answers
HI,
It might be a big or a small problem. It will not be possible to trouble shoot in a forum. If your computer is on warranty, try calling your technical support and the'll get it fixed for you. Or try calling a local technician for help...
Thanks and Regards
Posted on Mar 28, 2008
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Will not start. HDD power light comes on for about 5 seconds, then goes out. I put it on standby, started again, and put back on standby, has not come on since.
It could be a faulty battery. Remove the battery & try to power up the laptop.
If the laptop did not power up after removing the battery, then notice the power receptacle where you plug the power adapter's cord to the laptop. While plugging the power cord in, notice if there is a spark occurring at the power receptacle. If the spark occurs, then disconnect internal drives & connectors one at a time until subsystem with short is identified. If power input still a short with bare motherboard, replace the motherboard. If the spark did not occur, then inspect the boards for burnt or melted components, cold solder on DC jack, open connections, or unseated cards.
Feb 06, 2011 | Toshiba Satellite P105-S6084 Notebook
Does the toshiba satellite p105 s6084 support ACHI
Yeah it does support ACHI but you have configure it.
Please let me know if you have any further questions or concerns.
Thanks.
May 01, 2010 | Toshiba Satellite® P105-S6084 PC Notebook
Toshiba Satellite P105-S6104: Will not turn on
Power issues are pretty typical with laptops as most time laptops are moved around alot and are not stationary. Here are a few possibliites that could be the reason for you not having power:
1. A/C cord is could possibly be bad. Attempt to use the cord on another outlet, then try to use the same cord on another similar laptop to see if power is transmitted. If cord is faulty, then purchase another cord.
2. A/C input adapter on laptop is faulty. The A/C input adapter is where you plug your A/C cord into the laptop. This can come from the input coming loose or wiring being loose or disconnected.
a. check to see if the part is loose by touching the part with your finger.
b. if you are not a professional, take the laptop to a certifiied computer repair shop.
3. If you are a professional or are comfortable opening the laptop (do bare in mind you opening the laptop yourself violates any warranty you may have), then look at the A/C input adapter to see if it is loose or if a wire was disconnected from the motherboard.
4. If you are a professional or are comfortable opening the laptop, another option would be to check the circuitry on the motherboard to see if there is a bad transistor or circuit on the motherboard.
I hope this was helpful and thank you for contacting the experts.
Jan 08, 2010 | Toshiba Satellite P105-S6104 Notebook
NO power
Check the battery of your notebook pc .
when you charging it then try to turn it on if it starts and shuts down when you remove charging them there must be problem of the battery,then you have to change your battery from Toshiba service center.
Oct 23, 2009 | Toshiba Satellite P105-S6084 Notebook
When I play DVDs in my toshiba p105-s6084, it skips in sound and sounds all sketchy. It plays cds ok. what is wrong?
Sounds like you need to update the DVD Decoder, A very good decoder is Nvidia, roxio and Power DVD are ok. Hope this was helpful Good Luck =)
Jun 05, 2009 | Toshiba Satellite P105-S6084 Notebook
I have a Toshiba Satellite P105-S6084 My daughter turned it on. Windows started to load and then everything went blank and the computer refused to be turned on again. No sign of power
Take battery out of the back of laptop, put back in. if that doesnt help:
1.) remove battery from back of latptop
2.) remove cmos battery should be accessable through one of the panels on bottom of latop.
Are you getting any beep codes?
Jan 20, 2009 | Toshiba Satellite P105-S6084 Notebook
P105-S6084 Does not turn on at all.
i think you're right!you have to replace a new one honestly
Dec 31, 2008 | Toshiba Satellite P105-S6084 Notebook
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
