Question about Whirlpool Refrigerators
How can you tell if a GS5VHAXWA is cooling . Just got it today and has been plugged in and on for 8 hours and is warm inside.
  • gbbaby1 May 11, 2010
    Yes sounds like the fan is running. Control panel lights up turned to cool but it has been 8 hours and seems to not be cooling. I have an 8 year old WP gold that i am replacing and it cools in an hour. Is it typical for it not to cool much if at all in 8 hours?
  • steve
    steve May 11, 2010
    Is anything running? Fans? Lights? Is the thermostat turned on?
  • Whirlpool Master
  • 3,361 Answers
It should have started cooling immediately.
Call your salesman and have another delivered to replace it.
Posted on May 11, 2010
How do i loosen a spark plug with a 5/8" swivel spark plug socket?
Are you sure you are using the correct plug socket? Are you using a 6 point and not a 12 point socket, if not get a 6 point for more grip.
Aug 03, 2016 | Cars & Trucks
Plug in frig starts cooling will make a thin layer of ice in trays and frig fresh food will start to cool down then cooling stops and fan is still running. Unplug wait 30 min plug back in and starts...
That problem may take a little work finding but that is no problem if you can pull away from the wall and unplug. Then remove the lower cover that covers the compressor area so you can feel the top of the compressor. Feeling the top of the compressor tells me several things like if it has been running all this time or if very hot it will tell me that the compressor has been short cycling. Compressors short cycle for a few reasons and one is the start components photo #8 and #4 in this photo here=> ASD2628HES_COMPRESSOR_Components Another reason may be the evaporator fan or the condenser fan #20 in the photo link above are not staying on or there is an airflow restriction. When the compressor runs there should be a good steady flow of warm air from below the refrigerator. That warm air is the warm conditions being removed from inside your refrigerator. The most likely reason for this is the start relay/overload or number 4 in the photo has become defective. That is this=> Relay Overload with Start Capacitor
With that part out and able to get the=> 65889-4 15uf run_capacitor
out I would carry the run capacitor to a local refrigeration dealer and ask if they would test your run capacitor for free. I will be here if you should have questions beyound what I have mentioned here today, Thanks, Sea Breeze
Jun 13, 2011 | Amana 26 cu. ft. Side-By-Side...
I have a top freezer/refrigerator and notice that ice is accumulating in the freezer and underneath the freezer in the fridge. What are my settings supposed to be set at? What should I do?
It sounds as if your refrigerator has stopped automatic defrosting of the evaporator coil or has a plugged defrost drain.. Below is some information provided by: www.repairclinic.com, to help you understand what may be wrong with your unit. If it is not cooling properly, you may be able to get it cooling again, temporarily by removing all perishable items, unplugging the unit, and allowing it to stand idle wth the doors open. This will allow the ice to melt, which will allow air flow to resume normally through the unit. Allow several hours for the ice to thaw completely, then close the doors and return it to an operational status. Put water in both compartments and when satisfied with the results of temperature, i.e. frozen in freezer and cold in fresh food compartment, you can put perishables back in. This will allow normal operation for only about a week until the defective part gets replaced, then it will start warming up again.
If the drain is plugged then the diagrams should show the routing so you can clean it out.
Today, all but the smaller, apartment-sized refrigerators are self-defrosting. Self-defrosting means what it implies--though frost continues to accumulate inside the refrigerator, it melts automatically. The self-defrosting system has three functional components:
Defrost timer
Defrost heater
Defrost thermostat.
Defrost timer The timer is like a clock. It continually advances, 24 hours a day. Every 6 to 8 hours, the timer turns off the cooling system of the refrigerator and turns on the defrost heater.
Defrost heater The defrost heater is similar to the burners on an electric stove. It's located just beneath the cooling coils, which are concealed behind a panel in the freezer compartment. The heater gets hot. And, because it's close to the cooling coils, any ice or frost build-up melts.
As the frost and ice melt, the resulting water drips into a trough. The trough is connected to a tube that drains the water into a shallow pan at the bottom of the refrigerator. The water is then evaporated by a fan that blows warm air from the compressor motor over the pan and out the front of the refrigerator.
Defrost thermostat The process ends after either the amount of time specified on the timer or when the defrost thermostat near the cooling coils senses that the heat near the coils has reached a specific temperature.
Detailed parts diagram:
http://www.repairclinic.com/Refrigerator-Freezer-On-Top-Appliance-Diagram
Aug 13, 2009 | Whirlpool Refrigerators
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hii have an indeset fridge freezer 2 year old freezer ok fridge not cooling
Usual problem, let it defrost properly, I mean 48 hours with doors open in warm room. It is most likely frozen up inside (its frost free! no?) inside is a different matter and they dont tell you that!
Mar 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
I have a bad smell and taste in water and ice from fridge/freezer
Take out all shelves and accessories that can be removed. Wash these thoroughly with a mild detergent (dish washing liquid and warm water) and rinse thoroughly. Allow them to air dry completely.
* Wipe the inside walls of the refrigerator and freezer down completely with a solution of 1 quart warm water and 2 tablespoons of baking soda. Wipe the walls completely dry.
* Leave the doors standing wide open. Use a fan to circulate air through the cabinets for several hours to completely dry the inside walls. After several hours, turn the fan off.
* Replace the shelves in the refrigerator. Place shallow trays of one of the following deodorizers on the shelves of the refrigerator and freezer:
o Baking soda
o Activated carbon (used in aquarium filters, can be obtained at a pet store)
o Cat litter
o Fresh and unused coffee grounds (this may leave a coffee smell that would dissipate after several days)
* After 24 hours, plug in the refrigerator and allow it to cool for several hours with the deodorizer still in place. Once cooled to normal operating temperature, remove the trays of deodorizer and put your food back into the refrigerator and freezer.
* Keep some cereal size bowls of a deodorizer in the freezer and refrigerator cabinets for several days
Feb 28, 2009 | Kenmore Refrigerators
Humming sound unit does not cool
sounds like abad compressor, when it heats up its overheating and shutting off,i would check if the fan behind, next tot he compressor is blowing, and the lower coils are not cloggged
Jan 25, 2009 | Frigidaire Refrigerators
1999 Saturn SL1 trouble starting when warm
It was the coolant temperature sensor. It was telling the car that the coolant was always cold, therefore when starting a warm engine it was being flooded. $$$
Jan 05, 2009 | 1999 Saturn SL
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
