Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Glasses on upper rack getting food residue during cycle
At the end of the cycle there is a layer of dried on food residue inside the glassed that were placed on the upper rack.
It appears that the food is shot up into the glasses during one of the cycles and it is never rinsed out.
GE has come out 7 times and has not been able to fix the problem
Thank your for your help.
  • 1 more comment
  • Anonymous Sep 14, 2008
    Particles of food end up inside cups and glassed and are baked on during the drying cycle.  These pieces are not large so somehow larger pieces are filtered I think.  I haven't called GE yet, but will come back if I figure anything out.
  • Anonymous Feb 23, 2009
    On the glasses, I find the same small particles of food residue. I have cleaned the dishwasher but it hasn't helped. Any one know what to do?
  • Anonymous Mar 01, 2009
    Same issue with food residue.
  • 185 Answers
Is there anything blocking the spray or plugged in the spray arms check that
Posted on Mar 28, 2008
I have the same problem: while I can't take apart the whole machine, the upper sprayers don't appear to be clogged. I have tried the dishwasher cleaner product by JetDry and this did not do any good.
Posted on May 26, 2008
I have a KitchenAid Dishwasher Model KUDT03FTSS0. I am having a problem with the glasses on the top rack not being fully cleaned. There seems to be an amount of residue left on the glasses. I have...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 25, 2011 | KitchenAid Dishwashers
Dishes and glasses on the top rach are not getting clean-bottom rack is fine.
Jun 14, 2011 | Kenmore Dishwashers
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
The items on the top rack never come out clean. there is always food residue left. it seems that the final rinse doesn't get to the glasses. we need to rinse them all out before the drying cycle starts...
heatman101
Jan 04, 2010 | Amana 24 in. ADB2500AW Built-in Dishwasher
Top rack of dishwasher seems to deposit particles of food on to glasses so not only are they dirty at the end of the cycle, the pieces of food particles are difficult to scrub off them. This happens with...
check the holes on the sprayer for the upper rack, somtimes they get pluged up and the top rack dishes wont get sprayed off. if they are pluged remove them and wash in a sink
Oct 26, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dirt and residue left on glasses
wash glases alone ad a jet dry aditive to detergant  Vitally
Jan 26, 2009 | GE Profile PDW8600J Built-in Dishwasher
Film and food residieu remains on upper rack
Hi, is the wash arm underneath the upper basket turning freely and is it not blocked with any food particles? I've had items out of my dishwasher with a similar problem and it's been when the upper wash arm has been blocked or a spoon has fell through and prevented it from turning and washing properly.
Good luck.
Oct 04, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
469 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
