Question about Kenmore Elite 45986 Front Load Washer
WHAT DOES ERROR CODE F20 MEAN? JUST MOVED & HANDBOOK CANNOT BE FOUND RIGHT NOW.
  • 5,911 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. The following link explains some of the common causes of the error code and how to troubleshoot: http://www.fixya.com/support/r3608632-f20_error_code The error codes aren't listed in the owner's manual.
Each one of these washers come with a technical data sheet inside. To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information and let me know if you need assistance beyond what the tech sheet provides. I hope you find this information helpful.
Posted on May 11, 2010
F20 error code on maytag epic any idea what this means?
F20 means that the unit isn't detecting water is entering the machine quick enough. When the error code appears if there is little to no water in the tub, then you have an issue with either the water supply to the washing machine or the electronic water valve. If the washing machine fills up about 1/2 way up the door and is overfilling with the water, it means that your pressure switch is faulty and will need to be replaced because it's not detecting that water is entering the machine.
Mar 02, 2015 | Maytag EPICz 3.7 cu. ft. Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Getting error code e2 and
U2 this invalid or undue motion scanning device, lamps or copiers panels. It is Necessary to make sure that 2 and 3 mirrors are not bolted screw for transportation, they are found with left side, where the mirrors 2 and 3 stoped . For checking remove glass and try to move the scanning device. Avoid the reason of the stop. If no, search for the fault in sensor, on the left and on the right on движени скарующего device, they can be запылены. opposite event follows to call the service engineer.
Sep 10, 2009 | Office Equipment & Supplies
What does code F20 mean?
"F20" is a No Water Detect error code. The following link explains:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
Read through the link provided and check the obvious things first. This is an error code that can have several causes, so you will need to follow the steps provided.
If you still have questions, or require additional assistance, please let me know. I hope this helps you.
Jun 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
