Question about Viking VCSO244 Dual Oven
VDSC307-4bss how to operate self-cleaning oven
We use oven infrequebtly.. bought stove 12/04/2002. Finally got it dirty and we do not know where the manual is... how do we operate the self cleaning feature? Thanks
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Posted on Mar 29, 2008
SOURCE:
How do you clean 1993 thermador double ovens
you can't get parts for this stove anymore so i wouldn't use the self clean on it,use soft scrub to clean it it says not to use easy off on a brand new oven but at this point i don't think it would matter on a 20 to 30 year old oven,when you put a stove into self clean it gets up to 1000 degrees,the wire casings on older stoves break down as it is but with all that heat you can do some damage to the stove,even if you just bought a brand new stove using the self clean can damage the electronics in it,usually it will take out the computer board or clock assy. same thing,your clock is most likely broken on that anyway or something else could be wrong with it and most likely you won't get it to self clean but if you want to use it or try to get it into self clean go here and read from page 32 to 36 hope this helps you out but i would not put it into self clean
http://www.servicetechhelp.com/public/user-manual/14-30-789A.pdf
if this doesn't look like your oven get the model number and google it on how to self clean
Jan 20, 2018 | Thermador Ovens
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
There is an E1 F5 code appearing when I set the self cleaning button. I need your assitance. I have a Kenmore electrice self cleaning stove and it was in the house when I bought it six years ago. .
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
No instructions on how to use self cleaning Frigidaire range/oven
stove stuck in self cleaning mode door was open when cleaning mode was turned on will not shut now what do i need to bdo?
Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven
If your unit has such a feature, you can use it.  Get the manual from the company website.  It is located under customer support, generally.
If your unit does not have a cleaning feature, you cannot do this yourself since the temperature is higher than the oven can be set and the door cannot be locked to prevent injury.
Nov 28, 2008 | Ovens
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Viking VCSO244 Dual Oven Logo
391 people viewed this question
Top Viking Ovens Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Viking Oven Expert? Answer questions, earn points and help others
