Question about Maytag MER6772 Gemini Electric Kitchen Range
Only part of the heating element is warming up on the range.
  • Maytag Master
  • 3,361 Answers
You will have to replace the heating element.
Unplug the range.(Important step)
Remove the element from inside the oven.
2 screws at the back wall.
Replace the element.
Plug the range in and bake me some cookies.
Posted on May 11, 2010
2 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: Oven and burners will not heat up
have you checked your fuse/breaker panel for 120/240 volts and again at unit plug,sounds like you lost one leg of the 240volts and you only have 120volts and if its on the clock and timer side they will still work,but need 240 to heat elements fully
Posted on Jul 28, 2009
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Oven not heating at 350 - only gets warm. However broiler element works fine. Do I just need to replace lower element?
Sorry to read about your problem, I hope this helps you out.
it could be defective element, bad heat probe..or defective control knob..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
eewr
Dec 23, 2010 | GE Spectra JBP78 Electric Kitchen Range
Whirlpool elec. Single built in oven...lower element wont heat at all upper gets warm doesnt seem to get real hot. Metered lower element got continuity.metered wires to element nothing... Please help I'm...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 09, 2010 | GE JGBP26 Gas Kitchen Range
The oven will not heat past 250. The warming
There are two breakers or fuses, and either one of the circuit breakers has tripped, or one of the fuses has blown. Or, both elements have failed.
Let me know if you want further diagnostic direction., and if your comfortable with mechanical and diagnostic troubleshooting.
Dec 16, 2009 | Amana AER5722BAW / AER5722BAQ / AER5722BAB...
Jul 06, 2009 | Kitchen Ranges
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Oven will not heat?
check youe elements make sure there good if they u need erc if not replace element and try might still need both replasced
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore gas stove doesn't heat properly in bake mode,takes 2hrs to heat to luke warm. Smell gas when I open door. Works fine in broil mode
hi
the heating element is coroded better to change the heating element first clean the gas valves...
thank you......
Mar 06, 2009 | Kenmore Kitchen Ranges
Magic chef electric fee standing range model 35ja-26x
Sounds like a shorted element. This can happen if the element shorts to ground near the middle of the element. Current will then flow from the unswitched side of 240 VAC to nuetral or ground, heating up the same as if on 240 VAC.
Jan 24, 2009 | Magic Chef CER3740 Electric Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
185 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
