Question about TMI Products VizuaLogic 703-99000-6005 Chevy / GMC Pick-Up / Avalanche / Suburban / Tahoe 99/00 - 02 Med. Neutral... Car Video Player
HORN ON MY 1995 CHEVY PICK UP NOT WORKING HAVE REPLACED HORN AND RELAY. STILL NOT WORKING DOES ANY ONE HAVE ANY IDEAS
  • mikee1019 May 11, 2010
    with air bags
  • DDURAMAXMAN May 11, 2010
    with or without air bags?
    Problem Solver:
  • 17 Answers
Possibly the clock spring that has all the circitry for the air bags and the horn
Posted on May 11, 2010
1995 accord horn not working.hear horn relay clicking but no current at horns when checked with test light. bad horn relay?
Check your wiring diagram and check for power coming out of the horn relay. Suspect a bad relay.
Oct 26, 2014 | 1995 Honda Accord
How do I find test replace starter relay 95 chevy 1500
look under the lid or in your owners manual
swap it with the horn, ac compressor, or cooling fan relay, temporarily and see if it works then, if it does be sure to replace the bad one
Apr 29, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
Have a 1995 Chevy K2500 pickup. The horn relay switch is good, horn is good but it will no sound when pushing the horn on sterring wheel. What could cause the problem?
your horn button and wiring is ground for the coil side of horn relay, usually. My guess is problem with horn wiring in steering column, maybe a clock-spring issue? I saw two different years listed for your vehicle? It may not make any difference?
Jan 11, 2012 | 1993 Chevrolet C/K 2500
I have a 1995 Chevy S 10 and the horn does not work. I think my problem is under the dash. Are there any switches,relays, or breakers I need to be looking\r\nfor? I have traced from horn to fuse panel and...
The horn relay is in the fuse/relay box under the hood. so the fuse is HOT on both sides? you should hear the horn relay click when pressing on the horn switch. there may be other relays in that fuse box to swap with and see if the horns work, if the relay clicks, its "usually" good, but the contacts may be bad. if the relay clicks, check for power at the horn. DARK GREEN wire, if it has power , then check the black wire, thats the ground. If it has power and ground, but does not work, the horn is bad.
Sep 14, 2011 | 1995 Chevrolet S-10 CA Edition
I have a 1995 chevy tahoe, the horn will not make a sound you can press on the horn and feel it click but no sound. Is this something i can personally repair myself and how do i do that?
Check for voltage to the horn either while someone else presses the horn button, or by using a test light. You should get 12V between the horn wire and a known good ground. If you're getting 12V at the horn wire, then you probably need to replace the horn. If you don't get 12V when the horn is applied, then it is likely that the horn relay needs to be replaced.
Jun 27, 2011 | Chevrolet Tahoe Cars & Trucks
Horn not working. When depressing the horn button on the steering wheel, only "clicking" sound is heard near the front passenger side. Checked the fuse and turned out to be unbroken. What's next?...
The clicking you hear is the horn relay working.
I would locate the horn and insure the wiring is intact and the horn has a good solid ground.
Then while someone is pressing the horn button measure the voltage at the wire that attaches to the horn to ground. If you get 12v or more the horn is bad. If you don't get any voltage replace the relay
Jan 23, 2011 | 1995 Jeep Grand Cherokee
My horn quit working but when I press it it I here a clicking the car I'm driving is a 1995 chevy cavalier ls 2.2 liter
The clicking is the horn relay, which should click.
It must be that the horn is bad or disconnected
Oct 14, 2010 | 1995 Chevrolet Cavalier
Horn does not work on 1995 chevy truck ck. all fuses
check the horn relay
they are notorious of going bad
Mar 05, 2010 | 1995 Chevrolet K1500
LOCATION OF HORN FOR 1997 CHEVY PICK UP TRUCK
the horn on a 97 chevy i located behind the grille in front of the radiator
Feb 21, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
1998 S10 Chevy Horn not working
You most likely need a new clock spring rotating contact under the steering wheel, it is a plastic ribbon with wire in it to connect the horn button and other accessories to the steering wheel while allowing the wheel to turn.
Sep 22, 2008 | 1997 Chevrolet S-10 Pickup
Car Audio & Video Logo
314 people viewed this question
Top TMI Products Car Audio & Video Experts
greg benton
richie46
Tommie Jones
Level 1 Expert
Are you a TMI Products Car Audio and Video Expert? Answer questions, earn points and help others
