Question about DISH Network 721 DVR Remote Control
SAT light stays lit but no functionality.new batts, still nothing. reset DVR, still nothing
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Beavs72,
If the Sat button stays lite with no function to control the receiver, either the Sat button is stuck or the remote has gone bad, especially if you already changed the batteries. You can call 1-800-333-3474, speak with Tech Support and if needed, they can send a new remote. I hope this helps.
Ray Calo
DISH Network
Posted on Jan 20, 2011
No communication between receiver and remote
amandaharwoo,
The first thing I would do, if you haven't already, is replace the batteries in the remote. The lights will still illuminate if the batteries are low but won't perform the remote functions. If that doesn't fix the problem, the remote may need to be readdressed to the receiver. I have provided the steps below. If you have further problems, please respond to the site.
  • Remote: All Other Remotes
    1. Go to System Info screen
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button
    5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DSIH Network
Jun 13, 2010 | DISH Network 721 DVR Remote Control
Device code
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 10, 2010 | Jensen JR500 Remote Control
My 95 surburban wont crank changed the stater got a new batt and new batt post still wont crank
Obtain a 12 volt test light, ground the clip on the negative battery post, and check for light at the large terminal on the starter solenoid. If lit, have someone try the key--if the light goes out, place the light on the battery positive post and try the starter again. If it goes out again, either the battery needs to be charged, or it is defective. If the light stays lit in the first test, then place the light on the starter motor terminal and retry the key (do you hear a fairly loud click?). If nothing but the click, replace the solenoid itself. If no click at all, test the small terminal on the solenoid and try the key. If you get light, replace the solenoid. If no light, check for blown fuses. If ok, then suspect a bad ignition switch. Hope some of this helps!
Mar 31, 2010 | Chevrolet Suburban 1500 Cars & Trucks
I cant push the SAT button to control the satellite
Try pressing and holding the SAT button for about 6 seconds to see if it lights up, if not remove batts and hold SAT in till lights go out then replace batts and try again. your remote may need repalced if you have good batts and sat will still not light up.
Nov 30, 2009 | DISH Network IR Remote Control
Dvr recording pauses occasionally (for about 30 seconds) and freezes (which requires a reset or unplug).
Hi! I will be more than glad to assist you in this concern. If your directtv hdtv receiver occasionaly pauses for 30 seconds and freeze and the only troublshooting steps that you do is to press the power button for 10secs or unplug the power-hard reset for 15secs. please do this steps
1. check if the software version of your receiver is updated, how to? got to the sysinfo of your receiver by pressing the sysinfo button on your remote or front panel of the hd receiver, write down on a piece of paper the version, then exit the sysinfo, run a check switch test, you need to access the menu of your receiver, once your done with the check switch and test.. turn off the power of your receiver by pressing the power button on the remote, make sure that there are no lights lit so that the satelite will automatically download the software if its outdated and if nothing happen it means that your software is updated. after all the steps that you did, by running the check switch and test.. still problem exist.. call the directtv tech support for the replacement of your hd dvr receiver, this is a dvr lost of function. I have experience that symptoms on my hd dvr receiver as well with one of the sat provider..
note: if you cant run the check switch and test, please call the direct tv tech support for assistance.
please feel free to get in touch if you have any query..
Aug 30, 2009 | Directv HDTV Receiver
Seems like the car is staying in "ACC" (accesory key position)
BFC that body function controller. BFC batt fuse controls .the body function controller .its part of the PCM.the BFC controls anti theft system. your interior lights -drl lights- radio -door locks.if your check engine light is on take it to dealership.because your BFC and PCM works together. your car could shut off. that unsafe.when you on a busy highway.you have electrical problem.not a home fix.
Jun 27, 2009 | 1999 Oldsmobile Alero
Battery problems Tc 1100
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
May 05, 2008 | Compaq tc1100 Tablet PC
SHR 1040 "Froze Up"
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Dec 23, 2007 | Samsung 4 Channel Dvr
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
DISH Network 721 DVR Remote Control Logo
547 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
