Question about Onkyo TX-SR502 Receiver
No sound out of the main speakers. sound will play in center or rear speakers
    Problem Solver:
  • 11 Answers
Are you sure you have them plugged into the main speaker (Front) not speaker B? or make sure you dont have speaker B turned on only.
Posted on May 11, 2010
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
No sound from zone 2 speakers
yes,usually thugh the reciecer borrows power from your rear speakers so you(center channel) so you wont get that
May 11, 2009 | Audio Players & Recorders
REAR AND CENTER SPEAKERS WILL NOT PLAY
rear and center speakers will not play...................are you in the 5.1 channel input, or one of the others? either way, start by making sure that your center channel is set for normal mode (instead of a wide or a phantom mode) this silly setting can cause all kinds of trouble shooting nightmares especially particular to the 5.1 input setting. best reccommended to select the 5.1 input option and do a "t.test" on the system to ensure that all speakers are indeed wired and properly recieving some signal..... the rest will flow from there..... I have also noticed that in particular sound modes, the system is extremely finicky about the connections..... if you are using the 5.1 option, you need to be sure that something is plugged into the inputs on the back (regardless if they are connected to anything) the system seems to prefer when all ports are filled. hope this helps..... i realize that it has been a while since this question has been posted, but let me assure you, that some of us are still rockin those sava systems..... still by today's comparison, it is difficult to beat the sound quality and oh my the bass!!
May 09, 2009 | Sony HOME THEATER SYSTEM System
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Rear speaker not working
If you did the 5.1 sound test and the rear speaker works, sometimes you have to see in your software speakers settings,probably you need to change to 5.1 speakers
May 28, 2007 | Dell WL6000 Computer Speakers
Onkyo TX-SR502 Receiver Logo
122 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
