Question about ViewSonic VA1912w 19" LCD Monitor
Crawling lines on monitor
I have had this problem now for a few weeks, where there are moving horizontal bars that run up the screen.
I have unplugged all connections etc and checked other monitors however it is only appearing on this monitor.
  • 43 Answers
Try this first update your onboard or graphic card to the latest driver.
Posted on May 11, 2010
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
HAVE A 2011 AOC MONITOR BLACK AND GRAY HORIZONTAL LINES FILL THE SCREEN
Run a full scan using your anti-virus program to see if it will track down anything, next go to www.download.com Type: malwarebytes anti-malware and run the program with a full scan, "free" this program find just about anything that is lerking in your computer. Now! if all this fails, do a complete fresh install of your operational system.
Apr 18, 2012 | AOC 2436Vw LCD Monitor
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
White intermittant horizontal lines
Sure it can be fixed, I think some components on the main board needs resolder on their soldered joints. Try this first before thinkig of getting a new one.
Nov 30, 2007 | Videoseven W17PS 17" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
ViewSonic VA1912w 19" LCD Monitor Logo
104 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
