Question about Profile 200SX Car Audio Amplifier
Just received a profile 250, used, what wire do i hook up?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
  1. Fuse amplifier’s power wire at the battery.
  2. Be sure to fuse the power wire within 12” of the car's battery. This will protect the car's battery in case of a short circuit between the power amplifier and battery. THIS IS A MUST, the amplifier's built-in fuse will only protect the power amplifier not the car's battery.
  3. Use high-grade wire connectors. Use Proper power wire size for maximum current transfer and safety. Improper size power and ground wire can reduce the amplifiers power and poses a risk of damage to the amplifier and the vehicles electrical system. Please follow the recommended "Amplifiers Power Cable Requirements" to ensure maximum power transfer and safety.
  4. To ensure maximum power transfer and secure safe connections, it is recommended to use high-grade barrier spades (for connection at amplifier) and terminal rings (for connection at battery).
  5. Do not run any wires underneath vehicle. Exposed wires have a chance of being cut or damaged. It is best to run all wires through the vehicle under the carpet and/or side panels. This lends to a cleaner installation and less risk of damage.
  6. Use caution when mounting amplifier. Remember there are many electrical wires, gas lines, vacuum lines, brake lines, as well as a gas tank in the automobile. Make sure you know where they are when mounting the amplifier to avoid puncturing lines, shorting wires, or drilling holes in the gas tank.
  7. To avoid possibility of induced noise from the car's electrical system (i.e. popping noises or engine noise), Keep signal wires (Speaker or RCA) away from any electrical wires.
  8. In order to reduce the chance of ground loops (i.e. engine noise); make the grounding wire as short as possible to reduce the wire's resistance. Also, when using multiple components, make sure all units are grounded at the same point.
  9. Avoid sharp edges when running the wires. When laying wiring inside the car, watch for welding burs in channels throughout the car. If necessary adequately grind, finish sand or fill in around any ruff spots so wires will not be punctured by sharp protrusions. Use a grommet to protect the wire when running through the firewall.
any more ??'s look up profileuse.com
Posted on May 11, 2010
2006 Zongshen GS 250 wiring diagram
Hi, DJ for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Zongshen, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Zongshen GS 250 wiring diagram Google Search
Help with 2006 zongshen storm 250cc gs Page 2 ChinaRiders Forums
Zongshen gs 250 service manual
Specialist Online Chinese Bike Spares
https://www.ultimatespecs.com/motorcycles-specs/zongshen/zongshen-gs-250-2006
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 03, 2018 | Zongshen Motorcycles
Does a 1992 polaris trail boss 250 2x4 need a cooling fan, once ido find a used one how do you wire it to this bike
A 250 probably doesnt need a cooling fan unless you're hauling heavy loads slowly in hot weather.
Apr 15, 2013 | ATVs
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
How to hook up sony se501 speakers?
Good day Virgil. Please be a bit more specific. Are you using a Decoder to receive the TV signal? When you say " hook speaker wires to the TV" - do you mean via the Sony SE501 receiver??Just tell me what components you have and I can help you.
Sep 09, 2012 | Sony Str-Se501 Stereo Receivers
I have a 1995 Ford 250 pick up. Engine 460 V8. I am trying to find out how to hook up the wire to the electronic system for an RPM gauge. The older cars use to hook up to the coil, but the F250 has...
According to info found online, the wiring for a 1995 F series tach gauge is as follows;
Tach..........Tan/Yellow wire...........at coil connection.
Your truck does have a coil that feeds the distributor, correct?
Jan 18, 2011 | Ford F-250 Cars & Trucks
I need to hook up my tail lights on my 87 250 cmx
Get into Google or get Haynes/Clymer repair manual
Sometimes on intenet you can find free wiring diagrams
Mar 23, 2010 | 1987 Honda CBX 250
I hooked up a stereo system for a friend last night, and he has a 250 watt power acoustic amp, and he bought a 1200 watt amp wiring kit, is the wiring kit to powerful for the amp, because i hooked it all...
As I said in the previous post no the wiring kit is just fie. Yo uwill need to change the inline fuse and that is about it. The problem exists in how you have your subwoofers wired and what impedance is being presented to the amp. Please read my previous response to your your post.
Jan 31, 2010 | Car Audio & Video
Hooking up Pioneer DV 250 DVD player through Directv Satelite Receiver
i dont know what hooks up were on my tv i have rca jacks but cant seem to get it all to play , hell i dont even know what channle to put the tv on, i do have a cable box to
Sep 17, 2008 | Pioneer DV-250
Profile 200SX Car Audio Amplifier Logo
80 people viewed this question
Top Profile Car Audio & Video Experts
xxxxxx xxx
Are you a Profile Car Audio and Video Expert? Answer questions, earn points and help others
