Question about Sharp Office Equipment & Supplies
I have a Sharp AL1655 CS copier that keeps telling me to replace TD cartridge. I have purchased 3 different cartridges and get the same results.It prints about 20 - 25 prints then says TD cart near end of life then will not print anymore. I can turn the toner agitator gear on the toner cartridge and it will again print around 20 to 25 prints then says Td cart and end of life.
  • lazerstr May 11, 2010
    By calling this number are they going to tell me how to fix this problem, or do you know what the problem is
    He did not tell me what the problem was just a number to call. Am I going to get charged more when I call this number as well
  • 2,984 Answers
I am seeing probably the same thing you have already but when it comes down to this problem and you have already spent and wasted money on 3 cartridges, you should call the number below.
1-630-378-3590
Also, tell them that you want to be reimbursed for the last three cartridges also...
Posted on May 11, 2010
  • Greg Bernett
    Greg Bernett May 11, 2010
    No you will not get charged anything.
Sharp AL-1655 CS copier - machine is 4 years old and has new TD cartridge. It was dumping excessive toner which I cleaned up. Also, made grinding noise. When machine opened and TD cartridge removed, I...
The part that you are talking about is not from the fuser unit. It is from the drum unit, it is most likely the primary charge grid. It is part of the drum that charges the drum..... You may just want to replace the drum unit..... If the grid fell off the plastic holder may be broken... Good Luck
Mar 31, 2011 | Sharp Office Equipment & Supplies
Blinking U Blinking 2 in Display
When you press the copy key , it should show 40 and this is the solution. Remove the TD cartridge and unscrew the toner sensor and wipe with a small blower. Clean with a brush if the toner particle is stubborn and blow. Then screw back and clear with key press #*C* and enter16 then press copy key. If it re-appears, replace TD cartridge with Sharp AR-202ft. Enjoy the job.
Jan 07, 2011 | Sharp AR-M205 Copier
The printer says to replace the td cartridge and we just replaced it with a remanufactured one from Staples. The copier is a Sharp AL1655 CS
You may have just answered your own question.. Did you follow the instruction and take off all the tape.. Also, need you shake the cartridge side to side to looosen up the toner... If that does not work.... You know what to do
Apr 07, 2010 | Sharp AL 1631 Copier
I have a SHARP al-1661cs copier/printer. i keep getting a "replace TD cartridge" message. I have replaced the cartridge and it still come on every couple of days. i take the cartridge out, shake it and the...
Are you having your cartridges refilled?
By "replace TD cartridge" message do you mean the little stack of 6 red dots on the control panel?
The sensor for this condition is contained within the toner cartridge. The sensor reads the mixture of developer to toner ratio and tells the machine to add toner when needed. If you are having this problem with 3 different toner cartridges then I would suspect the toner add drive system. If you are having just the 1 cartridge refilled and have had the problem with the last 3 refills then the cartridge itself may be the problem.
I'll let you repond then we will see if further info is required.
Thank You for using Fixya.
Mar 29, 2010 | Sharp AL-1661CS Laser Digital Copier
On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
Nov 12, 2009 | Sharp AL 1631 Copier
How can install the sharp ar-5316 black and white cartridge
Hello sir; you have to open the side door first and then open front door , then slide out TD cartridge and drum cartridge, it will automatic reset.
Jul 11, 2009 | Sharp AR-5320 Black and White Copier
Sharp Al1655-cs Copy Issue
It could be the feed tires might need to be cleaned or replaced. You should check it our with a copier technician in your area.
Jun 26, 2008 | Sharp AL-1655CS Copier
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
