Question about Keurig Special Edition B60 Coffee Maker
I have a new keurig silent brew technology coffee machine. I had a different one for over a year but it was very loud, so I bought thisone. It was fine for about 2 weeks and all of a sudden it is turning itself off before I can make my second cup. It didn't do this at the onset. I checkedmy auto turnoff and it doesn't seem to be set. I am not sure what to do
SOURCE: Delivers only small amount of coffee per brewed cup
This is a scale issue. All water has minerals wich builds up inside the brewer through time. All you need is white distilled vinegar. Drain the Keurig first and then fill it with the vinegar. After the heat reaches brewing temperature, open and close the drawer to run off a few blanks (3 to 4 cups is plenty). This will prime the vinegar though all the lines. Refill the tank to the top with more vinegar and let the brewer sit (on) over night. The next morning, run off more than half of the vinegar. You should see the cup sizes drastically increase. Within a few cups, you should be getting close to the original 8oz cup. Repeat a few times for good measure. Drain the remaining vinegar, then flush a couple full tanks of good water through it. After all remnants of vinegar is gone, your brewer should work like new.
Posted on Jun 25, 2008
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Posted on Sep 30, 2009
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
espressonist
  • 1711 Answers
SOURCE: keurig only brews half a cup
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 15, 2010
B60 will not brew
This has run its course and be happy you got 6 years. Time for new Technology.
Mar 24, 2013 | Keurig B60 Coffee Maker
Keurig loud squeaking noise
End of life procedure "Say Good Bye" or have a fire!
Mar 03, 2013 | Keurig B60 Coffee Maker
My Keurig machine is loud when brewing the coffee. Very noisy machine is there anything i can do to reduce the noise?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 31, 2011 | Keurig B60 Coffee Maker
My Keurig says ready to brew but when brew button is pushed nothing happens.
Sorry to read about your problem, I hope this helps you out.
You can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
sfsfsf
Dec 23, 2010 | Keurig B100 Coffee Maker
I just bought my Keurig B60 new from a neighbor who bought it and used it once. She didn't like it becuase it didn't fill up her cup. I've had a single cup Keurig for years, but it finally stopped...
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Oct 03, 2010 | Keurig Special Edition B60 Coffee Maker
Does not pump water to brew coffee
well you can go back to the store where you bought or website and get a new one or send it back
Apr 06, 2010 | Keurig Platinum B70 Coffee Maker
COFFEE MAKER IS MAKING LOUD NOISE AND WON'T BREW COFFEE.
Do you have hard water or othe deposits in the water.? It may have just limed up. Try soaking it for a couple of days with Vinigar and water . put a healthy amount right in there add sum H20 and waite. this may free it up Good luck. DSFD
Apr 11, 2009 | Keurig B60 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
