I have replaced the battery in my pda when it would not power on. I can it to power on now by pushing rest button, but it turns off almost immediately after flashing "hold" on the screen. Any suggestions on what to try?
    President:
  • 2,923 Answers
If the battery is new and proven to be a good battery, then the problem has something to do with either the small components (i.e. capacitors, resistors, or fuse) or the software. It could have a corrupted software or busted components inside.
Unfortunately, this kind of problem should be taken care of the manufacturer, specially if the PDA is still under the warranty period.
The manufacturer has the complete components for replacement, and they need to upgrade the firmware of your PDA as well, and that should work correctly.
Thank you and good luck!
Posted on May 11, 2010
Sharp pda yo-370 will not turn on
okay this is what you gotta do unscrew the back of your PDA and you will see your two batteries and some stickers, in between the batteries there is a rectangle. take your screw driver and push the little bars inside the rectangle back. this will unlock your screen. if it still doesn't work hold the on button and press reset this will delete everything but also turn it on. if it still doesn't work throw PDA at wall, save up money, and get an IPad.
Apr 03, 2010 | Sharp YO-270P
How can do reset my htc touch p3450?
soft reset no data wiped off press the power button upside of pda for 5 seconds it will turn off then press it again to switch on
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 19, 2009 | HTC Touch P3450 Smartphone
Battery won't charge after being replaced
The charger might be bad. Or then the pdas connector is bad, or the motherboard is damaged.
to find out is your charger working you could use a tester to test it or another pda.
If you could get some power into the pda you could use the bootloader to test the device. Its been years since I had my 3850.
Il have to find instructions on how to get to the bootloader but test the other things first.
Drop a comment.
Mar 11, 2008 | HP iPAQ H3835 Pocket PC
My phone is lock
reset same time push the power button in and release them both same time and hold the red button for 15 secods until u will have window saying if u want to follow the restting process...good luck
Jan 22, 2008 | Eten Glofish M700 PDA
PDA displays only a white Screen
I recently replace my lcd and initially had that problem.  I fixed it by reseating the cable that connects the motherboard to the main phone piece.  (its the cable that is about 1/2 an inch wide and is very short, barely wraps around motherboard).  Reseat that and your white screen issue should be fixed)
Nov 30, 2007 | i-mate Pocket PC
PDA would not turn on...
try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Jul 24, 2007 | Dell Axim X51v Pocket PC
PDA intermitently powers up then freezes on "Palm Powered" screen
I had the same issue. What you need to do is to hold the power on/off button than press the reset button. The screen turns off (get black) than the will ask you to make a hard reset (which end up deleting all datas). The Palm will power on like the first time you turned it on after you bought it. Than depending which version you have it will possible ask you which language you will like to have as default. After selecting you neet to setup the rest. If this is done you sync it all data will come back :-)
Jul 04, 2007 | Palm Tungsten E Handheld
PDA will not turn on
If it isn't completely broken, I would recommend a few things:
1.hold down the power button, and push reset. It will ask you if you want to wipe the contents of your device. Push the button to cancel.
2.Pull the main battery and the backup battery. This will wipe everything on your device but it may get it up and running again.
Apr 03, 2007 | Dell Axim X5 Pocket PC
The Screen is back and it won't charge
Hello, it isn't that simple as a broken charger. Try the following thing. Connect battery to the PDA, check that the battery LID is connected FIRMLY to the body (there is a contact there that woun't allow the PDA to start if the lid isn't connected properly, you may want to check it too, look carefully for a small black thing and check that it can be pressed). Then connect the pda for half hour to the charger, even if no light or amber led is flashing. Then make a master reset as showed here and connect the PDA to a usb sync cable with your computer. Press simultaneous the soft reset and the power button, then press only the soft reset button. The PDA should start. If not, there is a problem with a DC converter component on the mainboard or the connector I was talking about before. Even if the charger is broken, your PDA should power on from USB cable. Good luck, feel free to ask further questions and always remember to rate replies received from this site :)
Feb 27, 2007 | HP iPAQ H2210 Pocket PC
My E-125 isn't working properly...
If your craddle has DC power input that charges the PDA while in craddle, try setting the power configuration so that when the PDA is on external power, there is no blank screen timeout, and no automatic shutdown (it's in the Settings menu). This way, it won't power down while in craddle, and you won't get this problem you're having.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
