Question about RTO Us Balance Usx-500 Digital Scale
Need instructions to recalibrate USX- 500 Scale
I need instructions to recalibrate a US Balance model USX-500. I lost my weight. I cant remember how many grams it was, or the proceedure, Thanks
How do I find out the weight of my 42LC2DB television for a wall bracket
If its not on the paperwork get your bath scale have some one hold tv and stand on scale. note weight put down tv back on scale note weight and subtract,
I am assuming it's not a 60 inch, if so maybe 2 people and 2 scales
mike
Feb 19, 2016 | Televison & Video
Error sign when turning it on. New batteries where installed
Possible that the LOAD CELLS are defective. Please check the main power and the feed to the processor and if the voltage are correct, then check for mechnical jamming of the tray . If there is no there observation , the fault can be the load cells. Estimate the cost of new cells, if possible get a trail piece for confirmation.
Sep 23, 2011 | RTO Us Balance Usx-500 Digital Scale
Cannot weight myself on the scale it did not come with the manual. It is the sharper image weight scale Model # SCSI-500
I have myself programmed at user 1
I don't have my weight in it yet.
I have wet feet and at one time the 0000 came up but can't get them to come up now.
How do I get my weight into scale for first time?
thank you
Nancy Sustersic
Jul 14, 2011 | Sharper Image Health & Beauty
For the Health-o-meter physician's beam scale, how do you know when it is in balance? What should you do to get it in balance?
For any scale you need to have a known weight to calibrate the scale. Try using something like a 5lb bag of flour or 10lb bag of potatoes.
On the top of the scale set the scale to whatever known weight you have on the platform and see if it agrees, if it is just slightly off, then use the adjustment screw to fine tune the scale, it will be at the end of the left side of the arm.
Dec 27, 2010 | Health-O-Meter Health o meter 402KLWH...
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
RTO Us Balance Usx-500 Digital Scale Logo
141 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
