Question about Brother PC8500D
Where can I buy a new mother board for my pacesetter 8500
My 8500 needs a new mother board wondering where i could get one
Can the LCD screen be replaced and also the start button on the brother pacesetter 2003D Some of the LCD touch screen won't work sometimes it does. Same with the start push button
Sorry, I just got on to this website. Sounds like your mother board has gone a wall. I has to buy one on line . It was priceyll perhaps time to invest in a new machine.
Jun 15, 2017 | Brother Sewing Machines
How do I deactivate a safety device on a pacesetter pc 8500
Um, I would take it for service. If the safety device has been activated, it very well could mean something is awry that could be dangerous.
Oct 12, 2016 | Brother Sewing Machines
How do I Lower the pressure foot for sewing after changing from embroidery on my brother pc- 8500?
Would a manual help?
Brother PC 8500 User Manual
Are the feed dogs in the raised position? Is it a regular stitch presser foot or a darning foot? A darning foot is shorter in height so the fabric can be maneuvered without use of the feed dogs. Just some ideas. Could also be an embroidery setting that has not been deactivated.
Oct 03, 2016 | Brother PC-8500 Pacesetter Embroidery &...
How do you change the main board
It doesn't look like there is much specific information about that online. You could carefully disassemble the sewing machine, remove the board, and connect the new board. Make sure to take a lot of pictures so you remember how to put it back together again. If you don't feel comfortable figuring it out yourself, I'm sure there are sewing machine repair shops that could handle it. Finding the replacement board might be tricky as well.
Jun 12, 2015 | Brother PC-8500 Pacesetter Embroidery &...
Why does upper thread break?
Check your tension, especially the tension disks for loose thread. Then rethread the whole thing.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Pc-8500 how to calibrate touch screen
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
What size bobbin is needed for brother sewing machine pacesetter 8500
It is a Brother specific bobbin for their older machines.
Nov 02, 2013 | Brother Sewing Machines
The feeder dose not feed
there is a switch on the back of most machines behind the feed dogs that allow you to drop the feet for embroidery, you have to switch it back to raise the feed dogs back up
Mar 04, 2013 | Brother PC-8500 Pacesetter Embroidery &...
Sewing Machines Logo
52 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
